Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > Best dvd/sacd combo
Author Thread: Best dvd/sacd combo
Username: Polksavage
Post Number: 127
Looking between 400-500
any suggestions
Post Number: 128
http://www.sonystyle.ca/commerce/servlet/ProductDetailDisplay?storeId=10001&cata logId=10001&langId=-1&productId=1002005
I'm looking at this one, I've found it from 5-6 other places between 350-450
Username: Cugine
San Jose, CA
Post Number: 21
It seems pretty expensive for not supporting 1080p. Even the next step up is 1699 and does not support 1080i. Any reason why?
http://www.sonystyle.ca/commerce/servlet/ProductDetailDisplay?storeId=10001&lang Id=-1&catalogId=10001&productId=1002005&navigationPath=45940n46021
Username: Larry_r
Naples, FL
Post Number: 1637
May I humbly suggest that you look at the Cambridge Audio DVD89. I think it has everything you want - and the quality is amazing. I have its "little brother," the DVD87 - and could not be happier.
Don't be fooled by the price - this is a quality player!
Username: Norcal_eric
Ukiah, CA
If you are looking for a multi-disc (5)player Marantz has a good scaler (1080p) in the VC6001 model. It came out at the end of 2006.
DVD-V, DVD-A, SACD-Multi, SACD-Stereo, DVD-R/RW, DVD+R/RW, SVCD, VCD, CD, CD-R/CD-RW, MP3, WMA, JPEG
192kHz/24-Bit Audio DAC | 216MHz/12-Bit Video DAC
Dolby Prologic II and DTS Decoders
Faroudja DCDi processing and NSV (Noise Shaped Video)
It is in the mid 500's at www.hifitrader.com
Username: Westcott
League City, Texas
Post Number: 153
None of these make the top ten at Secrets Home Theater.
The Yamaha - DVD-S2500 tops the list in your price range.
Hope this helps.
http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=all
Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > Best dvd/sacd combo [ « Previous ] [ Next » ]
