Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Sony 23" LCD turning on and off by it...
Author Thread: Sony 23" LCD turning on and off by itself
Username: Dumbo2929
Shrewsbury, MA
I have a Sony 23" KVL-23HR1 LCD flat panel that will turn on and off every 10 seconds or so, after warmin g up for a few minutes. The TV is 2 years old and has been fine. Could the external power supply brick be failing??
Username: Tamcagg
David,
Sony RPTV turning on and off in just seconds. Went through the whole check list called Sony (very nice and helpful) nothing. Now tried local guy...jerk... and haven't figured it out still!
Oh Please tell me you figured out what it was! I have the same problem. Just bought a new lamp.. going to try that today but have a feeling it's not the problem. WHat did you find out? Help Please!!! Another frustrated Sony owner.
Tam
Username: Bill984
Post Number: 238
I HAD A HITACHI THAT DID THE SAME THING A FEW YEARS AGO. I CAN'T REMEMBER WHAT IT WAS BUT I THINK IT HAD TO DO WITH HOW IT WAS SET UP. THE GUY CAME CHANGED SOMETHING WITH THE REMOTE AND PROBLEM SOLVED.
Username: Tapeman
Post Number: 606
I think you may have programmed it to auto turn off. Either reset PGM or change set-up. Doesn't sound like a serious issue
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Sony 23" LCD turning on and off by it... [ « Previous ] [ Next » ]
