Thread: Archive through January 30, 2007 |
Silver Member Username: Ke5aqn
Shawnee,
OK
Post Number: 647 Registered: Sep-06
| Posted on Saturday, January 27, 2007 - 03:59 pm: |
You can find the newest bin for you pansat 2300A HERE The newest bin for you receiver is the 261E. Please find the use the newest loader to load your receiver. After you download the files you can use winzip or winrar to unzip the files. If you need more instructions please just ask... To my shadow, I feel I answered in the best way possible for this moment. I feel it unnecessary to explain in great detail a bin that is not for his receiver, how to load a file with a serial port and cord, talk down to them, tell then each tiny detail, or how to unzip a file. Thanks |
Silver Member Username: Canndy
Www.livefta.com,
Www.livefta.com
Www.livefta.com
Post Number: 161 Registered: Nov-06
| Posted on Saturday, January 27, 2007 - 04:01 pm: |
New BEV keys... www.fta123.blogspot.com |
Gold Member Username: Nydas
Post Number: 1467 Registered: Jun-06
TEKNOFREAK: You have to be 100% sure that it is a genuine Pansat 2500A, to install BIN 289. Otherwise you should install BIN 288T. Use BL updater 1.4 and straight RS232 cable. More info on Pansats is at http://www.future-fta.info http://www.totlafta.com http://www.dssrookie.com http://www.dsstester.c0m If you go into Menu/system info and post the BIN number - it will be something like 2.79 and post it, we can tell what receiver you have, provided it was working with the receiver. |
New member Username: Syed33
TORONTO,
ONTARIO
CANADA
Post Number: 7 Registered: Oct-06
| Posted on Saturday, January 27, 2007 - 04:04 pm: |
Is there any solution for fortech ultra most of the indian channels are out can someone give me suggestion what to do, Thanks |
Post Number: 1468 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 04:07 pm: |
DN: Provider ID: 01 01. Keys updated on 18th January, 2007 Key 00: (86) 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 Key 01: (96) C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A Bev: Provider ID: 09 01. Keys updated today at 1409 Key 00: (86) DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 Key 01 (96) C4 3B D4 A9 11 8F 07 D8 CA 65 5C 6F 96 FE 80 A0 |
Shawnee,
OK
Post Number: 648 Registered: Sep-06
| Posted on Saturday, January 27, 2007 - 04:08 pm: |
New BEV keys DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 C4 3B D4 A9 11 8F 07 D8 CA 65 5C 6F 96 FE 80 A0 New Dish Key's 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A To my shadow, I feel I answered in the best way possible for this moment. I feel it unnecessary to explain in great detail a bin that is not for his receiver, how to load a file with a serial port and cord, talk down to them, tell then each tiny detail, or how to unzip a file. Thanks |
New member Username: Teknofreak
Post Number: 2 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 04:10 pm: |
PANSAT 2500A HI NALIN... OK HERE IS THE INFO ON MY BOX. X-85BL API:2.81Ta.EU BOOT VER 6.00 11/OCT/06 FUTURE_FTA HOPE IT WILL HELP TY NALIN |
Post Number: 1469 Registered: Jun-06
Syed Ahmed: I answered your question at 03:02pm today. See above |
Post Number: 1470 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 04:14 pm: |
TEKNOFREAK : You have BIN 281T. although you may have a genuine Pansat rpoduct, the BIN installed is a clone safe BIN. I suggest you stick to clonesafe BINs. Current version is 288T. A new one 289T is due any time. Since you have waited all these months, you might as well wait a couple of days and install 289T. The sites where to get them are mentioned above. |
New member Username: Nehal_3278
C,
D
C
Post Number: 4 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 04:17 pm: |
send me new key for BEV |
Post Number: 3 Registered: Jan-07
OK NALIN THANK U VERRY MUCH! |
Post Number: 1472 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 04:18 pm: |
Nehal: The keys are posted 3 posts above. |
New member Username: Aamir007
Fort Lauderdale,
FL
Post Number: 9 Registered: Aug-06
| Posted on Saturday, January 27, 2007 - 04:24 pm: |
Guys, I programmed the 289 bin but now have no picture but do have audio? Help |
Bronze Member Username: Eddy_2
Post Number: 12 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 04:33 pm: |
hi all i have a foretec lifetime ultra and a satellite antena with dual LNB. can someone help me to configure the dual LNB with the foretec because i didn't find any dual LNB in installation/antena setup/LNB type. thanks for your help |
Silver Member Username: Pathfinder191
Post Number: 154 Registered: Mar-06
| Posted on Saturday, January 27, 2007 - 05:19 pm: |
Hi all, Did anyone try bin 290 for Ariza 700 and 750? If so, please post your experience. Many thanks in advance. |
New member Username: Sternberk
Post Number: 1 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 05:57 pm: |
Nalin,You sure about 1409 for BEV because I try changed but without chance. |
Post Number: 1478 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 06:30 pm: |
freak: There are many variables. The Bev keys are confirmed by Keyripper, but not by keymaster. However, there have been and ECM on BEV for the last 5 days or so, corrected by newer BINs. You should evaluate on the basis of total information. |
Silver Member Username: Ustaad_hc
Post Number: 180 Registered: Oct-06
| Posted on Saturday, January 27, 2007 - 08:39 pm: |
sam i did . i have ariza 700 doesn't work. i try 289 then 290 still nothing.} |
Www.livefta.com,
Www.livefta.com
Www.livefta.com
Post Number: 164 Registered: Nov-06
| Posted on Saturday, January 27, 2007 - 08:43 pm: |
289T bin released for fortec and pansat: www.livefta.com |
Post Number: 1486 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 10:50 pm: |
X-85BL_070125_289T_db_api(N).bin by chancysand Moded for Hughes / Tivo ir codes. Good for ALL Pansat 2500 and clones and for Fortec Lifetime Ultra.! Get Serial Load Here: http://www.hostclip.com/dl/5626eb6001b02078663f34692111189f Get Full Jtag File Here: http://www.hostclip.com/dl/24aa9ac84ad839ea946b6c357fa9d223 |
Bronze Member Username: Hus
Post Number: 69 Registered: Sep-06
| Posted on Saturday, January 27, 2007 - 11:01 pm: |
Nalin isn't that bin by BL? |
New member Username: Ligiuta
| Posted on Saturday, January 27, 2007 - 11:14 pm: |
Nalin, please help me !! What bin do I need for Pansat 2700A. I don't know if is a real one or a clone. Thank you in advance. Ligia |
Bronze Member Username: Luqe
Post Number: 37 Registered: Sep-06
| Posted on Saturday, January 27, 2007 - 11:20 pm: |
Nalin, is there anything out for ariza 700 yet? |
Post Number: 1490 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 11:35 pm: |
Hus: Pansat BINs are usually by BL. They are initially not clone safe. They are then "modded" modified by Chancysand, who usually puts the letter T after it, and releases for you a clone safe BIN. luqman: No bin out for Ariza 700. |
Post Number: 1491 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 11:38 pm: |
Ligia: BIN for the true Pansat 2700A is out is labelled 292. There is no clonesafe BIN out as of this writing. Look at Menu/system info, and check the name of the BIN. If your BIN has a number something like 290, you can use 292. If it has number like 290c, it means that previously, at least, you had a clone safe BIN put in, so your receiver could be a clone. Then you will have to wait for a clone safe BIN |
Post Number: 5 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 11:50 pm: |
Nalin, how can I find if is an original or a clone one? When I bought it they list it as an original, but now I don't know. Thank you for your help. Ligia |
Post Number: 1494 Registered: Jun-06
| Posted on Saturday, January 27, 2007 - 11:52 pm: |
Ligia: Look at the current BIN number - I said how to just above your post. Post it to me and I will have some idea. |
Post Number: 6 Registered: Dec-06
| Posted on Sunday, January 28, 2007 - 12:02 am: |
Nalin is 290v1 tivo. You told me to download this one bacause it was safe. |
Post Number: 1497 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 12:06 am: |
Ligia: It is better toplayit safe and wait for the clonesafe 292 BIN tomorrow. I am almost sure it will be out tomorrow. |
Gold Member Username: Lklives
Post Number: 7350 Registered: Jan-06
| Posted on Sunday, January 28, 2007 - 12:20 am: |
Nagra2 Keys...FOR ALL RECEIVERS...from Keymaster 3.0 Dish Provider 0101: Last Updated (Jan18 4:30pm EST) Key0: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 (Active) Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A Bev Provider 0901: Last Updated (Jan27 12:00pm EST) Key0: DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 (Active) Key1: C4 3B D4 A9 11 8F 07 D8 CA 65 5C 6F 96 FE 80 A0 |
Post Number: 7 Registered: Dec-06
| Posted on Sunday, January 28, 2007 - 12:24 am: |
I found bin "pansat 2700 X-87BL 070125 292 api" is this the one? is on Dss central |
Post Number: 1500 Registered: Jun-06
LK: The keys posted above by you were already posted twice today at 4.00 pm. |
Post Number: 1501 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 12:29 am: |
Ligia: I have tried to explain before. There are two types of BINs for 2700A/E. pansat 2700 X-87BL 070125 292 api is the correct BIN,if you are 100% sure that your receiver is genuine and not a clone. If you put this BIN in your receiver and if it is a clone, it will almost kill your receiver. The other type is a clone safe. Currently you have a clone safe BIN in your computer. The clone safe version of 292 BIN is NOT out yet. |
Post Number: 7352 Registered: Jan-06
| Posted on Sunday, January 28, 2007 - 12:32 am: |
who cares...bin 289T was posted 10 times before U posted it...U are a hypercrite BTW, only reason I posted the keys from KEYMASTER, was because U lied and stated that Key Ripper has current keys at 14:09 but Keymaster did NOT..I believe U will notice that the new Bev keys were in fact posted and at noon, 2 hours prior to KeyRipper....so STFU bich! |
Post Number: 1502 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 12:38 am: |
LK: At the time I posted, Keymaster did not have the latest keys and keyripper had them. I make statements of facts. You were not looking at keymaster then, so you do not know. You need treatment and you should go and see your doctor about it, instead of going all over the forum, causing trouble. |
Post Number: 7354 Registered: Jan-06
| Posted on Sunday, January 28, 2007 - 12:40 am: |
STFU...yes, the keys were there then.. |
Post Number: 1503 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 12:48 am: |
LK: Do not come arguing with me. You are trying to fight an enemy that does not exist. You do not and cannot intimidate me. I said I looked and that is it. I have no preference between the two sites or for that matter any other sites that posts keys. So as I said before, you go and see your doctor and get treatment and in the mean time stop boozing and bullying. |
Gold Member Username: Prfrmnj
Post Number: 1713 Registered: Oct-05
| Posted on Sunday, January 28, 2007 - 04:12 am: |
LK - Naling is still trying to come down from her medication. Either that or she's been using the hell out of her DILLDOEE. Maybe she just doesn't comprehend. Either way, all she or he (I really don't give a fuuucckkk) is argue with anyone and definitively has to have the last word. Not woth it.... |
New member Username: Jubara
Hi Everyone, I can tell from all the answers that this forum will be patient on a brand newbie user like me. My question how to do factory flash or reset and if i want to put the bin file do i have to this factory flash ? ? By the way i am using ariza 700. Thank you in advance |
Post Number: 1715 Registered: Oct-05
| Posted on Sunday, January 28, 2007 - 04:21 am: |
JA - You do not need to do a factory reset. Just flash the file and you are done... |
New member Username: Xana
Post Number: 4 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 06:40 am: |
Thanks Nalin & Jay.Based on your replys,my best bet is to get a new more updated reciver.Any recomendation? Meanwhile, how do I get the STB for my Pansat 2300A? |
New member Username: Channelwatcher
Ontario
Post Number: 10 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 10:41 am: |
Hi, can anyone help me unstick my pansat 2500a, I was running with the 288t bin and it did a tp update and I shut it off . When I turned it back on it was stuck on english menu and wont exit off.I can got to install but thats it . I even loaded the factory bin again . |
Post Number: 1504 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 10:43 am: |
Alexandra Lobo: Your best bet is to change the receiver. A good buy is a Sonicview 4000- about US$ 180. A viewsat Ultra is equivalent priced. |
Post Number: 1505 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 10:46 am: |
Bruce: First reflash it with something like 280T, then reflash withthe latest 289T BIN. |
Bronze Member Username: Channelwatcher
Ontario
Post Number: 11 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 10:51 am: |
Thanks Nalin I will try |
Ontario
Post Number: 12 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 11:10 am: |
Nalin, did not work. getting worried , what to try next? |
Post Number: 1508 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 11:22 am: |
Bruce. Some of the problems, people have had in the past. 1. Wrong date and time or time zone. Make sure you have it correct before flashing. 2. 288T does not do an autoroll. 289T may have same problem. I usually make sure that the correct keys are in before I flash. Sometime the new BIN puts in old keys and the autoroll works and brings in new keys, sometimes the keys I put in stay, and sometimes, I have to turn auto roll off, do aset default keys, and load keys manually. One important thing I learnt is what is known as jtagless flashing. When you come to the point of doing the actual flash, i.e. when you are ready with the BL updater showing Com 1 and also showing the selected BIN for upload, keep one hand on receiver back switch, one hand on mouse to start uploading. Then switch on the receiver and immediately click to start the upload. Another problems which some newcomers have is that they don't wait long enough. Wait 20 seoncds after it say "Complete" How you can get going. |
Post Number: 1510 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 11:28 am: |
Bruce: If everything else fails, try the factory BIN, but I have not seen much difference in loading an old working BIN and loading a factory BIN to get started. Eventually you have to load the latest BIN. Hope the jtagless method works. |
Ontario
Post Number: 13 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 11:39 am: |
did all that still stuck. I cant get into the parental control or channel edit |
Silver Member Username: Albino_midget
Post Number: 399 Registered: Jul-06
| Posted on Sunday, January 28, 2007 - 11:49 am: |
Bruce, sounds like you need to do a complete set-up select language installation-antenna set-up select your sats, lnb type, diseq scan sats |
Ontario
Post Number: 15 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 12:01 pm: |
i tryed a reflash program and thet did not work I think you are wright I think I lost all my channels and need to rescan it all again (all three dishes) I will try this and let you all know |
Post Number: 5 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 12:30 pm: |
Thanks again Nadin.Apreciate your advice . |
Ontario
Post Number: 16 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 12:53 pm: |
Thanks Nadin and Albino, I rescaned it all loaded the new keys and all is good . My daughter loves me again and my wife says I might even get lucky tonight (life is good) |
Ontario
Post Number: 17 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 01:06 pm: |
life is good |
TORONTO,
ONTARIO
CANADA
Post Number: 8 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 01:15 pm: |
Where is loader for fortech, also the thread to download please can someone guide me, i hope nalyin can help Thanks |
Bronze Member Username: Zibruno
Post Number: 17 Registered: Sep-06
| Posted on Sunday, January 28, 2007 - 01:42 pm: |
hi nalian i downloaded the 289t but when i go to load it to my pansat nothing happens.Why does this bin have full jtag after.All the other bins never had that could that be the problem? |
Bronze Member Username: Trinity
Post Number: 21 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 02:14 pm: |
Hi How do I download the newest program for Panset 2700? Thanks. |
Silver Member Username: Dude123
Post Number: 890 Registered: Jul-06
| Posted on Sunday, January 28, 2007 - 03:36 pm: |
well first of all you need to download the bin file, a loader that loads the file on to the receiver and you also need a null cable to conect your receiver to the pc. get all that and post and i will post the step by step instruction for you |
Post Number: 1511 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 07:55 pm: |
home boy: You only use the serial version. The full jatag version is for those who want to or have to do full jtag. You might have to do a full set up menu/installation/antenna selection connect DiseqC in the selcted Sats, and then do a blind scan of sats. |
Post Number: 1512 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 07:58 pm: |
SYED IFTHIKAR AHMED : Go to the fortec section and download, the latest 289T BIN. Also download BL updater 1.4 and unzip both these. Get the instructions. Use a straight RS232 DB9 F/F cable. Upload the BIN, following the instruction when you upload. http://www.totalfta.com http://www.dssrookie.com http://www.dssevolution.com |
Post Number: 7368 Registered: Jan-06
| Posted on Sunday, January 28, 2007 - 08:08 pm: |
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released.. Some of these specialize in particular FTA receivers as noted next to their links.. If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community for many years now... Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information So again I highly recommend using ANY of these sites in this first post!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from a reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby! Final Solution Free To Air: http://www.fsfta.com/index.php (All receivers) Future FTA - Blacklist's Site: http://www.future-fta.info/forum/index.php (Pansat) Curious Contraptions Community: http://www.curious-contraptions.com/forums/ (All receivers) FTA Tech - Free To Air Community: http://www.ftatech.net/forums/ (All receivers) DVB Spider - Free To Air Technology: http://dvbspider.tk/ (Spacestar) Free To Air: http://www.f2atv.com/ (C00LSAT and All receivers) DSS Newbies: http://www.dss-newbies.net/forums/ (All receivers) DSS Evolution: http://www.dssevolution.com/ (All receivers) DSS Rookie: http://www.dssrookie.com/forums/ (All receivers) Global Airway Technology Specialists: http://www.gat-s.biz/forum/index.php (All Receivers) Total FTA http://www.totalfta.com (VIEWSAT and All receivers) Cut and Paste these into your browser: REMOVE the * in links below: http://forums.dsstester.c*om/ (All receivers) http://www.dsscommunity.c*om/forums/ (All Receivers) http://www.al7bar.t*k/ (All receivers) http://www.hashhu.c*om/forums/ (All receivers) http://www.dsscentral.n*et/ (All Receivers) http://www.pantecf2a.com/support (Pantecs,all clones and all receivers) http://www.gat-s.biz (All receivers) File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: http://www.ftacentral.c*om/ (All receivers) Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www.arachnoid.com/satfinder (Dish 500 support) http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm Satellite Charts -------------------------------------------------- For information on all satellites and channels they offer http://www.lyngsat.c*om/america.html http://www.satcodx.com/ |
Bronze Member Username: Liljdominican338
Post Number: 25 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 08:23 pm: |
i have no signal on ppv and sport can some one help me. thank you |
Post Number: 7377 Registered: Jan-06
| Posted on Sunday, January 28, 2007 - 08:25 pm: |
scan the TP's that those channels are on...its all listed at lyngsat.c*om |
New member Username: Deep_2000
| Posted on Sunday, January 28, 2007 - 08:44 pm: |
could someone plz help me .. I have ariza 750 i am not getting some of the chanls |
Post Number: 1523 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 09:08 pm: |
Post Number: 1524 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 09:09 pm: |
Jonathan Perez: What receiver do you have and when is it last you had these channels and on which satellite? |
Post Number: 1525 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 09:14 pm: |
Gary: Ariza 750 - New BIN is not available yet. Sam had posted yesterday a solution which seemed to work for him. It was a specific and unsual solution for Ariza 750. I am posting his solution below. "Ariza 750 users: Here is the solution for missing channels which I found out from another web site. It works great for me: bv and dn and yes you need to to a factory flash 2 time and after load 2.79 and after load 2.80 i guess that file is when the map 57 came out so it's only the ar is not working but for the moment is the only option .Need to put the key's manualy. I hope this help" |
| Posted on Sunday, January 28, 2007 - 09:26 pm: |
I dont know whole alot abt this stuf .. how would do all that u just told me.. |
Post Number: 1526 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 09:35 pm: |
It is quite long procedure and you will need help from a friendly computer hobbyist. You should go to one of the following sites and learn how to upload a BIN to your Ariza 750. EVERYTHING!! You will need to download the factory BIN for Ariza 750, and BIN s 2.79 and 2.80. You will to download the recommended uploader and teh instructions. You will need the appropriate cable - most liely it will be Null cable but find out when you read. You will need to read for at least 1 hour. The following sites will give you all the information and files in the Ariza section. http://www.future-fta.info http://www.totlafta.com http://www.dssrookie.com http://www.dsstester.c0m Best of luck. |
New member Username: Topy
| Posted on Sunday, January 28, 2007 - 10:10 pm: |
I am bounded to write my first post but i am fimilier with ever one in this site ,,, thx |
| Posted on Sunday, January 28, 2007 - 10:12 pm: |
This is really frustative to handle this kind of situation, sorry to say abt those people in this forum who known really as expert i am thinking the same way, but unfortunatly whenever point comes on Ariza most of the people dont realizes the importancy of the Ariza receiver users,,, cuz other then Ariza users are not suffering right now this much,,, please be serious to resolve this issued as quickly as possible,,, if u can ,,, hope is always high ,,, make this place top of the all dss forum, Thx |
Post Number: 1529 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 10:34 pm: |
RK: I note your concern about Ariza. However, people in this forum help in terms of what is available. Nobody here is a coder, as far as I know. We pick up the Ariza files as they are released and post the URLs to them. Ariza coders, I beleive are employed by the manufacturer or are a separate team that works indpendently of other coders and when they come out with a solution they broadcast to some relevant sites. No files are stored at ecoustics, so ecoustics does not get these files directly. |
| Posted on Sunday, January 28, 2007 - 10:47 pm: |
NN : Thxs to make me understand ,, |
Bronze Member Username: Palikeroako
Post Number: 33 Registered: Oct-06
| Posted on Sunday, January 28, 2007 - 11:18 pm: |
Please Help... Need New keys for the dishnet... Please help... ASAP....... |
Post Number: 1539 Registered: Jun-06
| Posted on Sunday, January 28, 2007 - 11:26 pm: |
DN: Provider ID: 01 01. Keys updated on 18th January, 2007 Key 00: (86) 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 Key 01: (96) C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A **--**--**--**--**--**--**--**--**--**--**--**-- Bev: Provider ID: 09 01. Keys updated 27 Jan at 1409 Key 00: (86) DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 Key 01 (96) C4 3B D4 A9 11 8F 07 D8 CA 65 5C 6F 96 FE 80 A0 |
| Posted on Sunday, January 28, 2007 - 11:39 pm: |
Thanks PRFRMNJ When you said flash the card you means just download the bin and that's it... Once aain thanks |
New member Username: Jack_jenlin
| Posted on Monday, January 29, 2007 - 12:00 am: |
Nalin, the Keys for the Provider ID: 09 01 (express vue) are not working for me. Could they already be expired? I'm a newbie here...so take it easy on me. |
New member Username: Usha
United States
Post Number: 9 Registered: Nov-06
| Posted on Monday, January 29, 2007 - 01:47 am: |
Does anybody know when there might be a new bin for Fortec star classic na. Please help |
Post Number: 1541 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 10:24 am: |
Jack Jenlin : BEV Keys have not changed since 27th January |
Post Number: 1542 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 10:27 am: |
Usha: There is no new BIN for Fortec Classic. |
Bronze Member Username: Gastrognome
Post Number: 12 Registered: Dec-06
| Posted on Monday, January 29, 2007 - 12:48 pm: |
www.tvkeyz.com www.filez.us/km3/keys.shtml |
Bronze Member Username: Rabih
Post Number: 14 Registered: Sep-06
| Posted on Monday, January 29, 2007 - 12:50 pm: |
Hello, recently i have lost alot of channels. I checked the bin in my box(pansat2500A) which I bought on e-bay and it was:X-85BL, API:2.79Ta-EU, Boot ver: 6.0 I asked one of my friends and he told that my box is a clone since there is a "T" in the bin format; I asked the seller and he said that the box is an "original" and not a "clone", he said too, "you can upload any bin to it either for original or clone". now I am confused about what bin should I upload and what loader should I use especially that it is the second box for this year and I don't want to ruin it. thank you. |
Post Number: 1552 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 01:40 pm: |
The clone safe BIN is OK for original 2500A and clones and Fortec Ultra. If you load BIN without a T on the end, you are taking a risk if you happen to have a clone, because it has clone killer code in it. The latest clone safe BIN is 289T. |
Post Number: 1553 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 01:42 pm: |
BL Updater 1.4 will always work well. You will need a straight RS232 DB9 F/F cable. |
Post Number: 891 Registered: Jul-06
| Posted on Monday, January 29, 2007 - 02:13 pm: |
and you can get the files from the following website: http://www.totlafta.com http://www.dssrookie.com http://www.dsstester.c0m |
Post Number: 892 Registered: Jul-06
| Posted on Monday, January 29, 2007 - 02:17 pm: |
Well if you want to find out if your box is real or a clone, then check out the following site and you will know http://pansat.150*m.com/fake.html ( remove * ) |
Post Number: 893 Registered: Jul-06
| Posted on Monday, January 29, 2007 - 02:27 pm: |
Jack Jenlin Try these keys, Bev just changed the keys. Nagra2 Keys Dish Provider 0101: Last Updated (Jan 18 4:30pm EST) Key0: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 (Active) Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A Bev Provider 0901: Last Updated (Jan 29 11:56am EST) Key0: DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 Key1: DE 4A A5 D6 45 21 FC 5B CF 95 2C 7C 78 81 F4 65 (Active) |
Post Number: 15 Registered: Sep-06
| Posted on Monday, January 29, 2007 - 03:12 pm: |
thank Nalin, I appreciate your help. |
Post Number: 16 Registered: Sep-06
| Posted on Monday, January 29, 2007 - 03:14 pm: |
Thank you Nalin, I appreciate your help |
Bronze Member Username: Jerseynigga007
Post Number: 24 Registered: Sep-06
| Posted on Monday, January 29, 2007 - 04:49 pm: |
What # is suppose to be in the LNBLocal-Freq. of Echo 3 thanx |
New member Username: Hjaved916
High point,
Nc
Usa
Post Number: 6 Registered: Jan-07
| Posted on Monday, January 29, 2007 - 05:43 pm: |
we need bin files and the newest keys for mercury11 thank you. |
New member Username: Manios
Toronto,
Ontario
Post Number: 4 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 07:00 pm: |
bev keys not working |
Bronze Member Username: Wwolf
Chatham,
On.
Post Number: 47 Registered: Nov-06
| Posted on Monday, January 29, 2007 - 07:45 pm: |
New Keys For Bell Key0: DB 24 36 EF 0A 72 AF 92 BA 93 D4 1C 8C 8B F0 64 Key1: DE 4A A5 D6 45 21 FC 5B CF 95 2C 7C 78 81 F4 65 Keys for Dish Key0: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A |
New member Username: Dena_86
| Posted on Monday, January 29, 2007 - 08:50 pm: |
Hello All I am really new to this and I know I am asking for alot but could someone please show me step by step where to get the new bin for Fortec Ultra Lifetime and how to download it and put it on the Reciever . THAT WOULD BE MUCH APPRECIATED. thank you so much   |
United States
Post Number: 10 Registered: Nov-06
| Posted on Monday, January 29, 2007 - 09:46 pm: |
Nalin Nyda:Do you think that there might be a new bin release soon or is there any other way to get the international channels.I thank you very much for your quick response. |
Post Number: 1557 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 10:13 pm: |
Usha: Did you mean for Fortec Classic? I doubt it. It might be that time has come for you to buy a new receiver. |
Post Number: 1558 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 10:15 pm: |
Dena : Go to one of the following sites and learn for at least 2 hours. Go to the Fortec section http://www.totlafta.com http://www.dssrookie.com http://www.dsstester.c0m Or you can read the last 100 posts here and you will get the gist of it. |
Silver Member Username: Jpz
MTL,
QC
CAnada
Post Number: 143 Registered: Jun-06
| Posted on Monday, January 29, 2007 - 10:16 pm: |
hi guys |
Toronto,
Ontario
Post Number: 5 Registered: Jun-06
| Posted on Tuesday, January 30, 2007 - 07:20 am: |
bev keys still not working, getting scrambled channel notice DN keys are fine |
New member Username: Vijayveena
Post Number: 2 Registered: Oct-06
| Posted on Tuesday, January 30, 2007 - 08:51 am: |
Thanks a lot guys. All your advices have been really helpful. Everything back to normal for the "time being". |
