Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > LG 42" Widescreen LCD HDTV** (42LC2D)...
Author Thread: LG 42" Widescreen LCD HDTV** (42LC2D)
Username: Mc_sunny
Post Number: 1062
Hi guys this my first HDTV i got it from futureshop for 1699+tax...I just wanna to know did i pick up a good tv with nice deal or wut ? And can you tell me how can i make my pic quality better...SHOULD I GO WITH HDMI OR companat vidoe cables....i am new to HDTV, so plz tell me more about this...i wanna gather more info as much i can..Thanks
Username: Tapeman
Post Number: 451
Hi McSunny
1699 is OK there were better deals on different products
First thing you need to know what HD reciver to plug
- i.e. Is it HD Antenna, Satellite, Cable, etc.
- Based on that you can decide HDMI or RGB
- For antenna no need to HDMI $100 rip off
- For Digital receivers/Decoders set the Wizard that will automatically change to 108i, 1080p, 720p, 720i, 480 etc. HDMI will be better picture if receiver is truely capable to handle it from optic port
Username: Mc_sunny
Post Number: 1063
Actually it was 1599CA which is about 1325US
These are the untis i hooked up to that tv right now
Satellite...Dishnetwork but dishnetwork receiver is not HD......Using comapant cables
Cable.....Normal CABLE...
Dvd Player.... using comapant cables
Xbox 360....I love the Game Pic it looks so nice...using Component HD/AV Cable i just bought that for 49.00CA
- so wut u think the cables i am using are they good or anything i need to change ?
Username: Mc_sunny
Post Number: 1064
component video cable*
Username: Tapeman
Post Number: 452
$1325 sounds much better
Most cable companies will charge $5 per month for an additional HD receiver. Ask your cable company if they can do that HD receiver good reciption. If they can do make sure it is the new optic one
If they don't get a $70 TERK amplified antenna straight coax to your TV no need for HDMI. Will get your local broadcast ch 2-69 as long as they are within 50 miles radius (much better than cable)
Username: Mc_sunny
Post Number: 1066
Thanks king, it was very nice of u to help me out on this. i will be coming in this section more often to learn more sutff..Thanks again
Username: Tapeman
Post Number: 473
Hey McSunny
Just like Satellite dish if you point antenna to get best reciption
http://www.antennaweb.org/aw/Address.aspx
You don't have to enter full info just city, state and zip the degrees will be Azmith
King
Username: Mc_sunny
Post Number: 1096
ok i will check this out..thanks
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > LG 42" Widescreen LCD HDTV** (42LC2D)... [ « Previous ] [ Next » ]
