New Product: Satcom Flat Panel Satellite Dish
Username: Worldftacom
Pensacola, FL USA
Post Number: 26
Here's a new item for you testers..
The Satcom Flat Panel Satellite Antenna..
Do away with the dish..
Uses Phased Array Technology..
Brochure below..
more info..
SATCOM PASSPort Mini Plus Flat Panel Satellite Dish Package - The ultimate portable satellite dish. This flat panel dish has no external LNB and requires no LNB support arm. Stores conveniently and compactly in it's own laptop-computer-style carrying case (included) and sets up in minutes. The included universal mount allows for easy attachment to tables, railings, benches, etc. The Satcom Flat Panel dish can also mount instantly to the optional Satcom #TP2001 Mini-Tripod or any standard camera tripod (not included). If you want the smallest, easiest, most lightweight way to receive satellite TV programming on the go, then look no further!
Includes 19' diagonally-measured flat-panel satellite dish antenna with built-in single LNB, universal mount, compass, 30' hookup cable. Compatible with legacy DISH Network & DirecTV systems. $350.00 MSRP
SATCOM Mobile SatCom PASSPort MDBS Flat Panel Satellite Dish - Receives Programming from Multiple Satellites! PASSPort Mobile Automatic RV-Mount Satellite Dish - This totally automatic 19" diagonally-measured flat-panel dish with no external LNB or LNB support arm allows for an unheard of super-low clearance of just 5½" in stow position! Completely automatic locating of satellite means no calculations for you to do. Just turn it on and relax as the Satcom Automatic Mobile Satellite dish does the work for you. It even works with multi-dish systems like the new DISH Network DISH 500 system by automatically locating the satellite with the channel you wish to view. Simple plug-n-play installation. Compatible with both DISH Network and DirecTV systems. Antenna platform measures 16.3"W x 16.17"L x 5.7"H. Control unit measures 8.5"W x 4.4"D x 1.5"H. $1,064.00 MSRP
SatCom's HDBS-2000 pairs military and aerospace technology in a stealth satellite dish that's so skinny it's nearly undetectable. The unique flat-panel receiver uses a phased array to grab and absorb satellite signals without having to focus them the way bulky, concave dishes do. The transmission is then processed by the integrated Low Noise Block filter and transferred to your receiver. The antenna, made from a UV-resistant polycarbonate plastic, mounts easily on your home's wall or roof.
HDBS-2000: $299.95 MSRP
More information on their website:
http://www.satcomweb.com/
Pensacola, FL USA
Post Number: 27
Here's the links for the manual
http://www.satcomweb.com/tech.htm
Username: Ke5aqn
Blink FTA TESTER /blink, OK USA
Post Number: 732
Interesting would like to see a review on it by a tester.
Username: Edenman
Post Number: 297
Very cool
