Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through January 24, 2007
Author Thread: Archive through January 24, 2007
Username: Dude123
Post Number: 865
DN, cricket ppv is on sports 471
Username: Larry1
Dawson creek, Bc
have the keys changed from yesterday if so tell me thanks
Username: Larry1
Dawson creek, Bc
Post Number: 7
have the bev keys changed from yesterday if so please tell me thanks
Username: Way2smart
CANADA
Moderator ®
Post Number: 171
its 472 i think
Username: Ricandlisa
ok friends , the keys from the 18 dont wrk for us ,, wondering , and advice ,
Username: Jpz
MTL, QC
CAnada
Post Number: 140
hi guys
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 148
www.fta123.blogspot.com - for latest keys..
for the new files being released to fix the latest problem visit www.livefta.com - friendly fta community made for the users by the users.
Username: Me_asim
ok..I just read the posts for last week or so and I have a Fortec star lifetime ( don't think it's ultra though --> it's half panel with three buttons in front and yeah panel doesn't come on) So would the best thing for me to buy a differnt receiver or anything can be done. I downloaded some uploaders posted on this site but can't upload any bins. Also tried following the procedures posted in this thread but progress bar just sits there at 0% or I get an error: communication failed...Any help/info will be much appreciated. Thank you very much for your time and consideration.
P.S. I am using this only for BEV
Username: Nydas
Post Number: 1330
Asim: You probably have the wrong cable. You need a straight through RS232 cable. In your current situation, if you buy a M/F 9 pin null converter, you can then use it in series at the receiver end of your current cable. That way you will have choice of both types of cable.
Use BL updater 1.4
Username: Me_asim
well Nalin, thanks for replying...I have a RS232 USB serial port to Male cable with a M/F convertor attached to my fortec...Do I need to get a F/F....I can attach that to my desktop....Also do you have any idea about the latest bin for my receiver...can i use the same one as for ultra or something else...thanks
Username: Nydas
Post Number: 1332
Asim. The BIN is 288T. Your cable system should give you a straight RS232, which is what you need. However you are not getting it. Perhaps your USB to serial is null, or your M/F converter is a null converter. Not knowing which is which, in your special case, I suggest you buy a M/F null converter, and use it in series with the rest. That way you are sure that you will have changed the total connection.
Currently USB TO SERIAL MALE + M/F CONVERTER both unknown, but not working.
Suggest USB TO SERIAL MALE + M/F CONVERTER both unknown, + M/F null converter to give you opposite of what you had.
Username: Nabil
Post Number: 49
hi
i have a pansat 3000, please can u help me... which bin should i use, im using the blacklist 1.4 updater and the bin 288t but it is not working, the screen is freezed
Username: Nydas
Post Number: 1334
You have the correct updater and BIN. I suggest you upload an older BIN like 280T, check that it get in alright and then try 288T.
Make sure you have the correct date/time and time zone.
Username: Hus
Post Number: 66
Hey guys I was wondering if the type of LNB matters in order to recieve Bev. Would a Ku-band type work?
Username: Nabil
Post Number: 50
thank you nalin
i have tried this with 284t its working but 288t its still not working
Username: Nydas
Post Number: 1335
kamal nabil: Use 287T or even 286T. You will be
OK for the time being
Username: Nabil
Post Number: 51
i have tried 287t and 286t the screen still frozen
Username: Nydas
Post Number: 1336
Keep it with 287T, make sure you have correct time, date and time zone andleave it be till tomorrow. I can't think of anything else to suggest, except to let it auto roll slowly for some reason. You could try manually loading keys, after doing a "set default keys" and autoroll off. You must load both Key00 and key 01.
Username: Lmwr
What the the steps to enter new keys? Bell not working.
Username: Lakers123
Post Number: 28
hello i have a question for a frinds sat, it is a ultra sat i can not find the bin on any of the websites they all have pansat bins but i am looking for the bin on a ULTRASAT US 4000
Username: Lklives
Post Number: 7246
John..never heard of that receiver...obviously it's a clone, and NOT popular...its appears to be a clone of a Coo*lsat 4000, which there are other similiar clones such as the megasat, digisat 4000, cooltec, coo-coo, etc...
There are 2 sites I know of with working bins for these clones...
www.dsscommunity.c*om/forums (in CLONES section)
www.totalfta.com
This is another reason why I suggest people use "REPUTABLE" Dss sites, they have what U need..
Username: Lolol
Post Number: 43
is there any english music channel on 148W??? i can't seem to find one. any help is appreciated
regards
Username: Nydas
Post Number: 1338
Ultrasat 4000 is a c00lsat clone and will not take newer c00lsat bins.
http://www.al7bar*tk/Forums/forumdisplay.php?f=322
Username: Leon_kookie
Post Number: 108
GREAT New Site....LK FREE ZONE
www.FreedomFTA.com
Username: Joecreosta
Post Number: 14
Does anyone have the new dishnetwork keys please? :-( i need them ASAP..please please please
Username: Nydas
Post Number: 1339
This morning, on Echo 3 (61.5W), I was getting all channels, using 287T BIN. 15 minutes ago, some channels were missing, notably SET, ZEETV. The situation was same as 3 days ago.
I loaded the 288T BIN. Autoroll was on. Keys did not roll in. I turned autoroll off, did a "set default keys" and put in the keys manually. The DN keys have not changed since 18th January. After saving, all channels including the missing channels are working fine now.
It seems that they fixed the Map 57 calls with the 288T BIN, but forgot to get autoroll working well.
Anyway, you can enter the keys manually and all channels work.
People with BEV are having problems with the 288T, and it seems it is important to check the keys and enter them manually if necessary
Username: Lakers123
Post Number: 30
thank you guys, so i can use c00lsat bins for my Ultrasat 4000, or will i have to find the bin for ultrasat on one of those pages, i do thank all of you for the help.
Username: Nydas
Post Number: 1341
john24: DO NOT use c00lsat bins on Ultrasat 4000.
Look at cooltec 4000 BINs and find out if they will work. Also inquire into Magasat BINs - if usable in Ultrasat.
If you test, make sure you know how to Jtag, if it does not work.
Username: Kochhar
Toronto, Quebec
anyone have dn keys?
Username: Gastrognome
Post Number: 9
Dish Network (Last Update: 2007/01/18 1:29 PM PST)
00: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26
01: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A
http://www.tvkeyz.com/
http://www.filez.us/km3/keys.shtml
Username: Fulali
Post Number: 21
Some of my channels were missing. I loaded 288T bin file(371KB size) which says it is clone safe, after which all channels were back. After working for 15 minutes my pansat 2500 clone died. No lights, nothing. Please advice me what to do now.
Username: Asharfi
Post Number: 494
Latest bins for the following receivers are now on www.dssworld.co.nr:
Fortec STAR Mercury II (Jan 22 ECM Fix)
Magnum XV3300 (Jan 22 ECM Fix)
Enjoy!
Username: Nydas
Post Number: 1344
Tahir: The latest clone safe BIN 288T is 371K zipped and 640K extracted version which you would upload. Get this BIN and upload it.
X-85BL_070118_288T_db_api(N)
Good for ALL Pansat 2500, Pansat clones, Fortec Ilfetime Ultra!
Get Serial Load here:
http://www.hostclip.com/dl/5e35d0cf284b5741959b26ab83afc112
Username: Lklives
Post Number: 7256
John, use the coo*lsat CLONE bins, like I suggested and told u where they are located..
ignore this nalin, she's a wacko...nobody ever suggested that U use a genuine coo*lsat bin!..and she likes to copy and repeat others..doesn't have a life or any friends, so she parades around here like the head MO!
Username: Wasim
Toronto, Ontario
Post Number: 21
Nalin Nyda - you explained earlier about entering keys again. Again i aint familiar much with all this, im using my hubby's userid and he is out of town, Do i just need to re-enter jan18th's keys again and all my channels will be working ??? or if anyone else could plssss enter my question
Username: Fulali
Post Number: 22
Please tell me how to recover my dead 2500 clone (J-tag) and from where I can get j-tag files and procedure
Username: Nydas
Post Number: 1345
The only Whako in Ecoustics is LK.
LK you are supposed to take you medication. Remember? you have to take you Citalopram as directed by your doctor.
John24: The clone bins that you are supposed to use are old and not valid for the latest ECM. You will get limited use of your ultrasat.
Username: Nydas
Post Number: 1346
wasim ahmed: The reason you have some missing somindo-pakistani (ZEETV, ZCINE and SET plus some Pakistani channels such as MUSIK) channels is that there is a repeat on a little problem DN and BEV created for us 2-3 days ago. DN stopped the bug but reintroduced it this afternoon. The keys have not changed since 18th for DN. Rentering the keys won't help. You need to upload a new BIN depending upon your receiver.
Username: Nydas
Post Number: 1348
Tahir: Try reading from
http://www.dssevolution.com
http://www.dsstester*com
http://www.totalfta.com
http://www.future-fta.info
Most of them require registration.
Username: Wasim
Toronto, Ontario
Post Number: 22
oh ok.... well now im gonna have to wait for my hubby wasim to come back and go get the bin file uploaded.
Thanks very much Nalin Nyda for the info :-)
Username: Asharfi
Post Number: 495
If you have C00lsat 8000HD receivers - That's the latest C00lsat receiver. It's latest bin for Jan 22 ECM is out. Yes, it fixes today's ECM problem. Get it from www.dssworld.co.nr! Enjoy! Also, some other ECM Fix bins are there.
Username: Dude123
Post Number: 866
lolol
the only music channel i know on 148W is trace i think its 591 it plays english and latin music, mostly latin, but some english for sure... wait for more replies someone might be familure with that 148W.
Username: Pinkblush
Post Number: 38
thanks a lot
Username: Dish_inq
Ontario
Post Number: 32
Can some tell me how to turn off Auto roll on Classic NA.
Username: Jaz06
Post Number: 19
With the missing indian channels-will they start working again or do you have to load the new bin file to it?
Username: Nydas
Post Number: 1354
Jaz: There is no option but to load the new BIN if you want SET, ZEETV,ZCINE, etc. It is not a key problem. When you load th enew BIN , you may find that the autoroll does not work. In that case, do a "set default keys" turn autoroll off and enter keys manually. Save and exit You may have to turn receiver off andon at the back.
Username: Hanz
Post Number: 201
Nalin, does the autoroll for 288T not work? Do you have to manually enter keys all the time using 288?
Username: Jaz06
Post Number: 20
Nalin I was asking because they did stop working for the day but returned again later on.
Username: Jaz06
Post Number: 21
Nalin also what do I need to load the new bin. I've never done it before.
Username: Nydas
Post Number: 1356
I have said this several times today and now once more.
Some receivers (not viewsats) stopped working on 61.5W - some channels only about 3-4 days ago. Some Indian and Arabic channels were affected. The problem corrected itself about 6-8 hours later. At the same time similar problems arose on BEV channels. The Bev channels problems have more or less persisted.
During the last 3-4 days new BINs have come out to address this mini-ECM. In the meantime this afternoon, the mini-ECM on Echo 3 (61.5W) was repeated. It is correctible with the new BIN. I have a Pansat 2500 clone, I have loaded the 288T BIN and the ZEETV,SET., etc are back.
Please read my posts in the last few hours in this thread about this problem.
There are a lot of posters here who have DN and do not watch Indian TV - they are totally unaware of the problems and will be outright rude to you for even complaining. Ignore them.
The 288T BIN is soewhat deffective but you need it if you have a Pansat 2500 clone. Look for similar new BINs for other receivers.
Username: Nydas
Post Number: 1357
For file downloads, BINs and instructions, I usually recommend some reputable sites. This is just a short list. There are many more good sites.
Try reading from
Username: Nydas
Post Number: 1359
Ranjeet: I found that the autoroll does not work on 288T and I had to manually enter the keys today after turning autoroll off. I found similar complaints in three other sites. It seems the coders addressed one problem, but forgot the autoroll portion.
Username: Hanz
Post Number: 206
Thanks Nalin, as always.
Username: Hus
Post Number: 67
Hey guys I downloaded the 288t for my pansat 2500 clone, every half hour or hour the channel says scrambled or bad channel, than my reciever turns off aftr 5 or 10 seconds, turns back on again and the channel comes back, I had a similar issue once before and i think it burnt my reciever, is it possible it can happen again?
Username: Hus
Post Number: 68
Hey guys I downloaded the 288t for my pansat 2500 clone, every half hour or hour the channel says scrambled or bad channel, than my reciever turns off aftr 5 or 10 seconds, turns back on again and the channel comes back, I had a similar issue once before and i think it burnt my reciever, is it possible it can happen again? I downloaded the file from totalfta
Username: Dish_inq
Ontario
Post Number: 33
Where can i find new bin for Classic NA?
Post Number: 15
Where can I get the new BIN file for my Ariza 700 ??? Can someone please help me out ASAP! I am getting some channels, but not all. This is crazy. please help meeee. tell me where i can get the new BIN file from...the keys that I am using are following:
Post Number: 16
Okay guys I think I have found the right BIN file for my Ariza700. Can someone please confirm this for me? dsstester-AA-1_H20070105_290eEU(N)_bgmain.bin but the question is how do I load up this file on to my Ariza? What kind of loader I need and what are the steps/instructions I need to follow. Please someone help me pleeez....!
Username: Mahmoud1966
where can i find new BIN for pansat2500 please thanks
Username: K98
Hey I just got my id on here will be chatin soon love the page
K98
Username: Prfrmnj
Post Number: 1515
Fidouh - Clone or Original???? If you are looking for original bins I suggest you get them at FutureFTA. If you are looking for the clone version go to Al7bar or DSSCommunity. I've tested both and they are on the up and up.
Username: Asplover
Hi Joe Yousif
Here's solution for u
U need a loader , go to authenticated site like dsster, dssrookie and get a loader for Ariza 700
Click on appropriate loader from the list of Ariza 700.U can download a how to guide too.
Just hook it up with ur pc , u will need a null modem wire from PC to Receiver to work with it.
Good Luck.
Username: Frobisher
Cambridge, Ontario
Post Number: 10
Is there a new bin for CW600s to get the missing channels on 61.5W, Echo 3? If so, where to get one and will autoroll work on it? Thanks
Username: Vasu_vijay
I have Ariza 700 receiver.International channels are missing from yesterday.Is there a new bin for this receiver?
hi is there new bin in pansat2500
Username: Angie_wedgewood
Ok dumb new person here.. So bare with me I have the latest keys (I have keyripper) but my channels still say scramble. I'm judging by the other posts I've read that I need a new BIN. I've never had to do anything besides scramble the channels, so I have absolutely no idea how to get a new Bin, what a bin even is, or how I go abouts changing it so that my channels work. Everything was set up for me when I moved in, so I really dont know how to do anything besides change the keys. I have a coolsat5000, if anyone could help me out with this it would be REALLY appreciate! Thanks!
Username: Asplover
Lost ZeeCinema And B4U from 61.5
I am using Ariza 700 with bin 2.90 which is the latest from 5-jan-09.
I have lost B4U and ZeeCinema from the Channels lists, have re-scanned again and again and still not getting them back at all. Any ideas ?
thanks
Username: Hanz
Post Number: 210
You'll have to upgrade to new bin, asp lover. New bins released last week to address the 61.5 channels issue. 61.5 got hit last week, then came back, and then yesterday they got hit again.
Username: Hvs
Post Number: 17
There is no bin still available for ARIZA 700. 290 is the latest bin as on now. And it does;nt work. Some channels still shows up like Sahara, AajTak, ZGuj etc....
You better wait for couple of days. Possibly it might start automatically as it did last time few days ago.
Username: Lizz
As Hus mentioned previously, the same thing is happening to my receiver (channels become scrambled, receiver turns off and then on again)after I downloaded the new 288T bin.
Username: Hanz
Post Number: 213
288 bin seems like junk. It solved the 61.5 issue although it has no autoroll and apparently it's causing disruption as has been reported by several people on here.
Username: Luckydraw
Quebec
Post Number: 14
does anyone know if the new bin file out for the 4000,if so can someone tell me where i can get it ,thank-you very much.
Username: Kochhar
Toronto, Quebec
is there new bin for cs5000 for 148w?
Username: Mc_sunny
Post Number: 990
Bev New Keys: 01/23/07
key0: 0510F08A9F1922E6FAC3F457A4A0B80B <-Active
Key1: FB31EC24458ED5EF3636F81CC98FA571
Username: Cs_1520
is autoroll off or on? will my DN channels work? thanks MC Sunny
Username: Ke5aqn
Shawnee, OK
Post Number: 439
This thread is stupid. How could you ever expect to get a answer from a question in a thread were 100 people are all posting? Its like being in a busy chat room trying to talk to one person.
wasim,
your question is a easy one I could get you the instructions SAD we never got to answer you in the main forum.
kuli,
that question has been asked several times today and solved...in the main forum
Angie Wedgewood,
We can solve you problem easily as well..
This is just a few examples of questions we could have solved in a more timely manner if a new thread was started......I understand this thread is "open minded" but this is getting SILLY.....I have posted the instructions on how to make a new thread it is the best way to get hlep that way you can see if anyone answered your question without having to load this huge page..If you regulars don't like it tough it just makes senceUpload
Username: Networm
Hi Guys,
C00l4K - no zee, sat, satmax, b4u, etc why?
rgds
Username: Ke5aqn
Shawnee, OK
Post Number: 440
Vikas I have the answer for you
Always start a new thread after you have read the new post from today to see if the same problem has been addressed.
read the forum its been addressed all day
Username: Nikk
Post Number: 955
Is this a thread for keys or what???
Username: Ke5aqn
Shawnee, OK
Post Number: 444
Nikk,
The idea of this thread was just for keys. It has turned into a huge unorganized question-answer thread as well.
So in short yes this thread is just for new key's how you would ever find them here is beyond me now.
Post Number: 10
Username: Canndy
Www.livefta.com
Post Number: 153
www.livefta.com - free files
www.fta123.blogspot.com - live keys
Bev: Last: Jan 23 14:25
00, 86: 05 10 F0 8A 9F 19 22 E6 FA C3 F4 57 A4 A0 B8 0B
01, 96: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71
Username: Palikeroako
Post Number: 31
n e new keys for D.N.?? Please help... Thanx in Advance....
Username: Charly_d
Montreal, Quebec
Post Number: 29
hi guys.
i reformate my pc and i lost all files and uploaders special the bl1.4 loader could you give me the site to download it again
thank's
Username: Canndy
Www.livefta.com
Post Number: 156
carlos you can download all uploaders and files for free at www.livefta.com
Post Number: 32
Do the codes work??? Someone help please...
Username: Dude123
Post Number: 868
They keys/codes havn't changed for BEV &/or DN since Jan 18/2007. If you are not getting any channel for any particular reason, that means you still have an older bin file downloaded on to your receiver. Upgrade your bin file and you will be able to watch all PPV, and international channels.
Username: Dude123
Post Number: 869
Nagra2 Keys
Dish Provider 0101: Last Updated (Jan18 4:30pm EST)
Key0: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 (Active)
Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A
Bev Provider 0901: Last Updated (Jan18 12:00pm EST)
Key0: 76 3A 51 F9 0C 98 26 55 52 C6 BD BF C6 09 C7 C9
Key1: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71 (Active)
Username: Nydas
Post Number: 1368
Jay: If you do not like this thread, you do not have to post answers here. You are a knowledgable person, and any help you can give people will be very welcome by them.
Username: Nydas
Post Number: 1369
DN Provider ID: 0101. Keys valid since 18th January, 2007.
Key 00 (86)
Key 01 (96)
Bev: Provider ID: 0901. Keys 00 (86) changed today.
Key 00 (86)
Key 01 (96)
Username: Nydas
Post Number: 1370
Ranjeet Bins posted the following about BIN 288T. I am confirming this as my experience too and simililar experience has been posted at many other sites.
"You'll have to upgrade to new bin, asp lover. New bins released last week to address the 61.5 channels issue. 61.5 got hit last week, then came back, and then yesterday they got hit again.
88 bin seems like junk. It solved the 61.5 issue although it has no autoroll and apparently it's causing disruption as has been reported by several people on here."
However, if you are scanning Echo 3 and want some special channles like SET and ZEETV and some arabic channels, you will have to put up with the BIN 288T. If you are scanning BEV, it is even more important to keep this latest BIN, and tolerate its shortcomings.
The same comments apply to a lesser extent to people who are installing a BIN for other low speed receivers, out in the last 3-4 days to counter the mini-ECM
Username: Dish_inq
Ontario
Post Number: 35
Is there any new bin out for Fortec Classic na
please help
Username: Teenvar
Pointe Claire, Quebec
what is bin 288T???
Username: Ke5aqn
Shawnee, OK
Post Number: 455
teen
its a bin for clones and the clowns that must have those 10 or so channels that were "lost"
Username: Nabil
Post Number: 52
please bin for pansat 3000 help please
Username: Ke5aqn
Shawnee, OK
Post Number: 457
Kamal
http://www.future-fta.info/Forums/
Their is the HOME forum for pansat
you will find the .bin file their
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 91
Hi can anyone help me i have a sonic 1000 i was wondering is there a bin that i can download the dish channels and the bell express vu?? and were or the name of the file please, thank you!
Username: Lklives
Post Number: 7294
Pansat 3000 is a CLONE of the genuine Pansat 2500, and Future does NOT support clones...U can use Future for the how to guides, but NOT bins...except the factory bin 222 or 224...I suggest U use any site, and always remeber to use CLONE SAFE pansat 2500 bins wihich ALWAYS end with the letter "T"...present bin is 288T, NOT 288, for the pansat 2500 clone, a pansat 3000..
Username: Zk44
Post Number: 8
sanu ek pal chen na aye sajna tere bina...KUCf
Username: Lakers123
Post Number: 32
Hello, i have a question seems like this thread is for help, so if someone can help me i have a ultrasat us 4000 also a pansat 3500 i have pluged the ultrasat into my usb port with the cable and it does not detect it and it says problem detecting hardware, how can i find the hardware to install bin on there i would apreciate anyones help thank you
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through January 24, 2007 [ « Previous ] [ Next » ]
