Home > Message Board > Home Video > Rear Projection TVs > Archive through January 29, 2007 > Need help samsung color wheel prob.
Author Thread: Need help samsung color wheel prob.
Username: Mrage
Post Number: 18
I installed an air bearing color wheel in my hlp5063, the color of the picture looked like a photo negative so after reading post i found that you need to unplug a jumper cable, I dont have a jumper cable but a place on the dmd board where it should be with a solder ball on it if i heat up the solder and remove it should i get my picture back to normal?
Home > Message Board > Home Video > Rear Projection TVs > Archive through January 29, 2007 > Need help samsung color wheel prob. [ « Previous ] [ Next » ]
