Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through January 19, 2007
Author Thread: Archive through January 19, 2007
Username: Ligiuta
the keys are not working !!! Does anyone have the new ones? PLEASE !!!
Thank you,
Ligia
Username: Nydas
Post Number: 1247
ligia girboan: The keys I have posted above are working for DN and BEV. Make sure you put the right keys with the right ID. If you have a BIN older than 1st Decemebr, 2006, change the BIN and anstall the newest BIN.
Username: Ligiuta
Thank you Nadin, I do have an older bin. What bin do I need for Pansat 2700 ?
Thank you for all your help :-))
Username: Nydas
Post Number: 1248
There is the regualr 290 BIN, but I prefer to use the clone-safe BIN.
http://www.dssrookie.com/forums/b-font-color-cd2626-2700-files-font-b/pansat-c-2 700-290v1-tivo-115645.html
Pansat-C 2700 290v1 Tivo
This is the 290v1 Clone Safe Beta Test....
Use the Pansat-C 2700 Downloader.......It can be found in in the 2700 files section
You can also find it at other sites.
Username: Usha
United States
Could you tell me what to do,i have downloaded bin 287 t on my computer and its sitting in my documents. First of all ,do i turn off the receiver and if not what is the next step. Please if you could give me step by step directions i would be very greatful and thanks in advance.ps:I have a fortec classic na and thanks again Nalin Nyda.
Username: Ligiuta
Thank you Nalin, it works just fine.
Username: Prfrmnj
Post Number: 1382
Maria - Those channels are part of the distant network channels that are going to be spot beamed into the respective areas. Therefore you will not be able to get them.
Usha - Go to this thread and read the instruction posted for flashing Fortecs & Pansats:
http://forum.ecoustics.com/bbs/messages/2/280111.html
Read the instructions I posted there for flashing. If you happen to have Night Rider Lights then refer to Nalin's instructions.
Username: Eatfish111
Post Number: 70
All the latest keys and files including clones can be found at http://ftamorvex.com/index.php its free to be a member.
Username: Nydas
Post Number: 1249
Instuctions for uploading a BIN for Pansat 2500 and clones.
1. You will need a 9 pin F/F cable - for Pansat 2500 and clones it is a staight DB9 RS232 cable.
2. Download the 287T BIN. Unzip it using winzip.exe
3. Download BL Updater 1.4
4. disconnect the cable from the LNB or Switch coming into your receiver.
5. Keep the receiver off and connect the DB9 cable to the receiver and computer.
6. Start (Run) BL Updater. Default COM1 should be OK in most case, but if it does not work you can change it to COM 2.
7. Select BIN and get the 287T Bin ready in the window for uploading.
8. Be ready to start both the receiver (the switch at the back) and the upload.
9. Switch the reciver on, and immediately click on the mouse to start the upload process.
10. You will see uploading in progress to 100%.
11. WAIT, WAIT. You will see the notice burning the flash ROM.
12. After the ROM burnng, you will get the message of completion. Wait a little and then turn off the reciever.
13. Disconnect the receiver, connect it to the LNB or Switch and turn it on.
14. Let the autoroll work - if it does not, turn autoroll off. Make sure the time and zone settings are correct. If necessary, install the keys manually.
15. Scan your satellite if necessary.
Username: Nydas
Post Number: 1250
In the above instruction if you have a 2700, use the appropriate loader that comes with it and use the 290 clone safe BIN.
Note that Pansat 2700 uses a Null cable, not a straight cable
Username: Prfrmnj
Post Number: 1397
The process described by Nalin above is for fixing receivers with Night Rider lights which is what you have now! This happens when the boot sequence in the system is interrupted and the only way to fix it now is to follow the same proceedure.
The process below is for normal flashing of Fortecs and Pansat Receivers.
8. Turn your receiver on from the back and allow it to complete its BOOT Sequence.
9. Once you see the "ON" on the front display, turn it off from the front.
10. Now commence your download and wait until it is completed and the receiver reboots.
11. Turn power off from the back.
12. Disconnect the receiver, connect it to the LNB or Switch and turn it on.
13. Let the autoroll work - if it does not, turn autoroll off. Make sure the time and zone settings are correct. If necessary, install the keys manually.
14. Scan your satellite if necessary.
It is very imprtant that you follow these in order to avoid getting night rider lights! While I know others would like to argue this point, I've been doing it for a long time and rather then attempt to dispute this I suggest you try it first.
There has been every now and then a receiver that just didn't want to work, but then I've forced the bin in using Nalin's proceedure which are the correct proceedure to follow if you have NIGHT RIDER LIGHT only...
Username: Prfrmnj
Post Number: 1398
Sorry Nalin! Wasn't sure if you were going to cut and paste these as well.
Username: Nydas
Post Number: 1251
PRFRMNJ : No offence meant and no offence taken. The process I am describing, I have used continuously in my Pantec since June, 2006, including a number of times I have changed the BIN just to test something. It has never failed. Perhaps the Fortec procedure and Pantec procedure is slightly different.
Anyway, at least, our instructions won't lead anybody to regret using them
Username: Prfrmnj
Post Number: 1399
Nalin - I've used both processes and have never had problems. I have found it much easier to do the on from the back and off on the from only because there is really no timing involved.
The other reason I normally recomend this one is because of the boot issue. I never recommend disrupting a boot sequence, but I have seen and tested the process both ways.
Post Number: 72
latest keys and files found at
free registration
Username: Will_d
Post Number: 19
nalin,I keep getting write failed [er1] error messaages,can you help me out?
Username: Nydas
Post Number: 1252
Will D: Uploading a BIN is an exact procedure, so you must follow instuctions religiously.
You could have wrong cable - there are two type straight and Null.
You could have the wrong BIN.
You did not unzip the file containing BIN.
A previous upload has caused a rpoblem - you could get out of this dilema by uploading an older BIN or factory BIN.
The serial port (usually Com1) has to be changed to COM2 or COM 4.
Username: Will_d
Post Number: 20
thx nalin,i will try to repace these steps and I will let you know if it works.thx in advance.
Username: Hshakarchi
Post Number: 81
Bev Keys pls
Post Number: 82
found these keys on another site,
00/86 is active,changed Wed Jan 17 14:21:09 2007
00/86: 76 3A 51 F9 0C 98 26 55
52 C6 BD BF C6 09 C7 C9
01/96: 12 29 12 48 B9 FE F4 07
CC 1C AD CB 1A AF 0A D2
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 115
www.LiveFTA.com - Latest keys
Bev Keys: Last: Jan 17 13:20
Key 00, 86: 76 3A 51 F9 0C 98 26 55 52 C6 BD BF C6 09 C7 C9
Key 01, 96: 12 29 12 48 B9 FE F4 07 CC 1C AD CB 1A AF 0A D2
KEY 00
00: 76 3A 51 F9 0C 98 26 55
01: 52 C6 BD BF C6 09 C7 C9
KEY 01
00: 12 29 12 48 B9 FE F4 07
01: CC 1C AD CB 1A AF 0A D2
Username: Hjaved916
High point, Nc
Usa
Does any one have Fortec star mercury II software and keys can you please sent to me or post them. any active keys thank you
Username: Canndy
Www.livefta.com
Post Number: 116
Latest Dish and Bev keys:http://www.livefta.com/forums/t1939-latest-keysspan.html
Fortec Mercury II file: http://www.livefta.com/forums/t1946-fortec-mercury-ii.html}
Username: Mynorlopez
Milton, Ontario
Hi everyone, I'm new in this on free air tv and I come to this forum to find the "new keys"but I would like to know were you gays find them, in the first place, to update us all.
By the way! I'm from Guatemala and live in Toronto, Canada. Could someboddy share this with me?}}
Username: Canndy
Www.livefta.com
Post Number: 117
You find them from http://www.livefta.com/forums/t1939-latest-keysspan.html
Username: Bertoro
Toronto, Ontario
Post Number: 469
maynor....si quieres ayuda vete al de español...espero sepas quein soy,,,,jajajaja
hasta que al fin te animaste a escribir algo
Username: Bertoro
Toronto, Ontario
Post Number: 470
otra cosa..solo como consejo, no creo que usando esa palabra que usaste para los muchachos les agrade mucho..pon atencion a la palabra que usaste
Username: Kenbelk
Ontario
}Can somebody please post dn keys instead of sites to go to that don't have them.
Username: Lklives
Post Number: 7144
Nagra2 Keys
Dish Provider 0101: Last Updated (Jan08 8:36pm EST)
Key0: 7B A3 12 F7 A3 07 68 38 87 2D E3 D5 A1 09 51 11
Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A (Active)
Bev Provider 0901: Last Updated (Jan17 3:30pm EST)
Key0: 76 3A 51 F9 0C 98 26 55 52 C6 BD BF C6 09 C7 C9 (Active)
Key1: 12 29 12 48 B9 FE F4 07 CC 1C AD CB 1A AF 0A D2
Username: Lklives
Post Number: 7145
Link to keys as posted in Keymaster 3.0....use this if U do not want to download keymaster or come to this forums or any site to get the latest and current working DN and Bev keys...just save this to your computer favorites after opening up the link..
http://www.filez.us/km3/keys.shtml
and here's the direct link to Keymaster 3.0 if U want to download this small utility and always have the keys on your desktop..
http://www.dsscommunity.c*om/forums/viewtopic.php?t=1786
Post Number: 83
DISH NET KEYS PLS
The ones posted are Not working for me,
did they change...
Username: Bertoro
Toronto, Ontario
Post Number: 471
nope, no changes hanibal..must be you
Post Number: 85
since no one responded if there has been a change
on DN keys, i have a scrambled screen, I have echo 61.5 , does anyone know if there is a change in it .....
Username: Lklives
Post Number: 7148
hanibal, if U can't read the replies here to U above...and think I post BAD keys...and don't even know how to input keys correctly, then I highly recommend U SUBSCRIBE...especially since U've ben here since lat May, 8 months ago...and still can't even input keys correctly!
after 8 months, if U still can't figure out FTA, then give it up!...this is a easy week of learning, NOT 8 months!
Post Number: 86
LK cool it man!!!
I can read, the keys are fine, something is wrong with my sat Echo 61.5 , I have deleted the sat and rescan it, the signle is good I can watch some TPS the others are scrambled, went to Lyngsat to check if they have shifted some TPS, its the same, It was working fine last night.
Bev Though is working fine with al TPS . My echo 61.5 is alligned perfect, any suggestion LK. Thanx
Username: Salime
hi please can some body help me for DN keys
Username: Loikku
My Pansat , 61.5 is down!!!!! Help me!!!
Channels 596, 597 off but 577 is working!1!!
Help me !!!
Username: Adave
Post Number: 37
me too i have old file for 27 sep 2006 so which file i need and loader too where i find out
thax
Username: Canndy
Www.livefta.com
Post Number: 118
Dish keys: Last: Jan 8 18:24
Key 00, 86: 7B A3 12 F7 A3 07 68 38 87 2D E3 D5 A1 09 51 11
Key 01, 96: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A
KEY 00
00: 7B A3 12 F7 A3 07 68 38
01: 87 2D E3 D5 A1 09 51 11
KEY 01
00: C6 3E 92 9C 14 C0 41 41
01: 05 7A FC 35 A4 4D 0E 8A
Bev Keys: Last: Jan 18 9:05
Key 01, 96: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71
KEY 00
KEY 01
00: FB 31 EC 24 45 8E D5 EF
01: 36 36 F8 1C C9 8F A5 71
Active Key in Green
GC Keys
ID C101
Key0 EB 4A C4 1A 45 5B DD 23 54 7E EF 4B 3A BF 4D 62
Key1 83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1
www.livefta.com
Username: Dude123
Post Number: 850
dave patel
Go to one of these sites and download the latest file and loader for your particular receiver. And make sure when you post a question next time give some more details about your receiver, like your pansat ( 2300, 2500 2700, or 3500 ???) clones or original? what bin file you are using? what loader you have? It just helps the other users to answer your question properly.
Sites:
dsscommunity dot com
dssevolution dot com
futurefta dot com
good luck
Username: Lklives
Post Number: 7151
Nagra2 Keys
Bev Provider 0901: Last Updated (Jan18 12:00pm EST)
Key1: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71 (Active)
Username: Leon_kookie
Post Number: 101
Username: Jaz06
Post Number: 14
Need help, my fortec ultra says bad signal since this morning, I turned off and on but still the same thing. There aren't any new keys are there?
Username: Jaz06
Post Number: 15
hello anybody out there???
Username: Nydas
Post Number: 1256
Jaz: If you were viewing DN, the keys have not changed. BEV keys have changed today at about 12:50 and are posted above.
Username: Mc_sunny
Post Number: 972
Dishnetwork New Keys
Key0: 0FE629BE9FEF4111A4C8403AD3A35826 <-Active
Key1: C63E929C14C04141057AFC35A44D0E8A
Username: Jaz06
Post Number: 16
Still trying to fix my fortec ultra. Just changed the DN keys but still says scrambled or bad signal message. any suggestions,please???
Username: Canndy
Www.livefta.com
Post Number: 120
www.livefta.com
Dish keys: Last: Jan 18 46:45
Key 00, 86: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26
KEY 00
00: 0F E6 29 BE 9F EF 41 11
01: A4 C8 40 3A D3 A3 58 26
KEY 01
www.livefta.com
Username: Harsirat
Post Number: 30
i've tried these keys but i am styll getting "BAD OR SCARMBLED CHANNEL"... How do i fix this??
PLEASE HELP!!!!
Username: Canndy
Www.livefta.com
Post Number: 123
Did you turn off autoroll? If not I believe the internatinals are going...
Username: Lklives
Post Number: 7156
Nagra2 Keys
Dish Provider 0101: Last Updated (Jan18 4:30pm EST)
Key0: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 (Active)
Username: Jaz06
Post Number: 17
my autoroll has been off for a while now. tried rebooting but still nothing.
Username: Palikeroako
Post Number: 30
need new DN Keys please...... Theses keys not working...
Username: Lklives
Post Number: 7157
keys work fine...and those are NEW keys!...can't u read and see the date and time!
Username: Nydas
Post Number: 1257
THERE ARE PROBLEMS WITH MANY CHEAPER RECEIVERS ON ECHO 3. VIEWSATS ARE WORKING FINE. BEV ALSO IS GIVING PROBLEMS.
IT IS NOT A KEY PROBLEM EXCEPT THAT BEV KEYS HAVE CHANGED TODAY.
WILL KEEP YOU POSTED.
Username: Lklives
Post Number: 7158
it has NOTHING to do with CHEAPER receivers!
Username: Canndy
Www.livefta.com
Post Number: 126
Sorry Nalin Nyda, but "cheaper receivers" comment is not valid.
Check this thread for the ECM:
http://www.livefta.com/forums/showthread.php?t=2260
Username: Dishoom
Scarborough, Ontario
Post Number: 117
any new kesy for pansat this keys not working
Username: Canndy
Www.livefta.com
Post Number: 127
Vim, it is working, maybe you want to watch international channels, then you will have to wait.
Username: Nydas
Post Number: 1259
LiveFTA.com and LK: I do not have to take notice of a new site of and old pest. The fact remains as I stated, and I will investigate further and post.
I suggest that while there is a hint of an ECM on, do NOT clutter up this thread with conflicting comments and suggestions to read elsewhere.
Username: Nydas
Post Number: 1260
I am confirming that Echo 3 has many missing channels on many receivers. Viewsat and Sonicview seem to have escaped so far. There is very little problem on Echo 8.1 and Echo 7.
Username: Canndy
Www.livefta.com
Post Number: 129
The Map57 code everyone has it... viewsat and sonicview 'escaped' because they already updated their receivers with the map. So all the other receivers just have to do the same. This ECM is nothing big.
Username: Nydas
Post Number: 1263
LiveFTA.com : You were not on this forum during the last big ECM, when every day for the first month people like you kept on predicting it will all over in a day.
I suggest you stay out of the guessing game and stop spamming your site.
There is a definite ECM going on but so far not in a big way. It will end up with a new BIN, hopefully in not too distant a future.
Username: Canndy
Www.livefta.com
Post Number: 130
Nalin Nyda, sorry I was not here when the last ECM hit. Maybe now we can have different opinions on this issue which is a good thing.
My opinion is that this ECM is nothing big because Viewsat still has map57 in their software and every other guy has the code.
Your opinion is respected too.
Username: Lklives
Post Number: 7159
respect her opinion, my azz...lol...LiveFTA, U are correct...nalin knows sh*it about this hobby, nevermind an ECM....LOL...don't let her push U around...she is no "straw" boss here...don't pay any attention to her..she can't even confirm her own existence!...she just likes to think she's a "somebody" other than a welfare mother sitting at home sucking the system dry!...why do U think she's into free TV, she canno't afford to pay for it...and never did DTV or DN plastic, cause she couldn't afford the loaders, unlooers, a good sub bin/cam and access cards, and DEFINITELY didn't have the brains to figure out how to do some REAL testing!
Username: Nydas
Post Number: 1266
LK: Go and take you Citalopram. You should have some phenothiazines as well, or ask your doctor to change you to Lithium.
LiveFTA.com: Facts are welcome. Opinions have to be given with extreme caution. I also make a mistake at times and give out an opinion when a statement of hope is more appropriate.
Username: Nydas
Post Number: 1267
The following is a C/P from a senior poster at CCC, a technical and reputable FTA site. He knows what he is talking about.
"Join Date: Sep 2005
Possible Map57 in Stream again!
Well, of course we have had our fun lately. But, I believe there are some confirmed reports from sources that Map57 has been implemented on BEV. Look for Dish to follow suit.
Two things are possibly happening here. Either BEV channels are moving to new provider (same as Sunday Ticket) or there is a REV update in the stream only for BEV now. I have read post where folks have lost VENus on their C00lsat 5000/6000 and decided to use their AUX card, and guess what, they came back in. Atemga's and other emulator type testing equipment are using map3b to work, and are black on certain channels. Look for more news as this week goes by. Hope you guys have your necessary equipment. Go dust off those card readers, get ready for IKS again, and of course the Viewsat will still be running hot(since last summer).
Ok folks here is the scoop.
It looks like BEV and DN both are starting to play some games on us today. I will break it down as I know it by provider so far
BEV:
Recent channel changes to Plyboy to the new providor index for NFL SUnday ticket seems to be expanding. Some Vu channels, Venus channels, and normal channels are making the switch today. So far VS and Pansat seem to be not affected by the changes, but Neusat, Captive Works, Skyview and C00lsat are.
DN:
Chuckie added a new provider id to his stream as well last night during the crazy key change some of us experienced, where they keys did not actually change. So far there I am missing about half of the international channels on 61.5, I would say look for more internationals to be hit later today. This so far has been affected on ALL stb's.
As soon as we know more we will report back here in this thread."
Username: Lklives
Post Number: 7161
"This so far has been affected on ALL stb's."
NOT TRUE!
More bogus c/p info from the NON tester nalin!
Username: Nydas
Post Number: 1270
LK: Take a hike from here. Your worshippers are waiting for you with your dose of Citalopram.
Username: Dude123
Post Number: 852
new keys work fine, make sure your autoroll is turned off if you are using the older bin file, and if you have the older bin file i suggest you go and download the newer bin file so you don't have to put in the keys manually every time the keys get updated.
Username: Lklives
Post Number: 7166
It all depends on which receiver and sats U are aimed at!...some working , some NOT...ita a map 57 ECM again...VS and sonicviews are holding well...Bev and DN 61.5 are going down, and expect all of DN to go down next couple days, until the other manuadacturesr's and coders come up with the map57 fix again...VS made it an open source..
Username: Jayscomputers
IIIIIIIIIII need help!! how do i turn OFF this auto roll on my fortec classic na, i tryed everything! please!!!!!!!!!!!
Username: Larrydumass
Stuppitville, Ark
Werdufunkarewe
Post Number: 28
who in the hell is mike jones
Post Number: 102
LK the player
Username: Imnycusa
Post Number: 46
new keys for most part are working fine. however, some channels on 61.5 TV (Asia, SONY, SMAX etc.)are displaying "bad or scrambled channel" message. anybody else is having the same trouble ?
Username: Nydas
Post Number: 1272
imnyc:
I posted this a couple of hours ago. There is no change in the status since.
"I am confirming that Echo 3 has many missing channels on many receivers. Viewsat and Sonicview seem to have escaped so far. There is very little problem on Echo 8.1 and Echo 7."
There is a similar problem on BEV channels as well.
Username: Salime
hi please can some body help me i have pansat 2500 and somme chanel of dishnet can't had image like art and art movies
Username: Salime
Username: Shivsai3
i have a pansat 2700. the reciever doesnt have any sat. signal, even after installing the latest bin file and after the factory flash. i know LNB and DISEqC are good. please help.
THANKYOU
Username: Nydas
Post Number: 1273
fidouh : Just read one post above yours.
kenny : Which satellites are you scanning?
Username: Shivsai3
i am scanning 61.5.
Username: Nydas
Post Number: 1274
kenny: Read my post 4 above. You should have about half the channels on 61.5
Username: Shivsai3
Nalin:signal quality ramins o.itried every thing,it was working fine for last 8 months.this problem started 2 weeks ago,signal started going weaker and weaker,now 0.
Username: Nydas
Post Number: 1275
Kenny: It is cheaper to buy a new DiseqC switch and try it, before suspecting LNB.
Username: Nydas
Post Number: 1276
Or you might have accidentally disconnected the software setting of DiseqC - go to Menu/installation/antenna/echo3 and see if there is a diseqC connected in software, exactly where it is in the hardware on your roof
Username: Shivsai3
Nalin:my dn. recivers are working fine,so i know LNB is good.even when i hook my pansat with SW64 switch signal guality is 0.when i hooked my pansat direct to LNB signal guality is 0.
Username: Vasu_vijay
HALK OF CHANNELS IN DISH NET ARE NOT WORKING(LIKE SUNTV,SONY,TV ASIA)ETC.I HAVE A ARIZA RECEIVER.HOW DO I FIX IT.CAN ANYBODY HELP PLZZZ.
Username: Nub2fta
N/a, N/a
Post Number: 24
Is BEV down for you folks ????
Username: Khaloudi
why does my satellite say tp channel update then it deletes the channel.
Username: Salime
please can somme body help me for some chanels didn't work in echo3
(DN) like ( zeetv zeecinema b4u and art ,artmovies, abudabi) i have
pansat 2500 please help me
Username: Nydas
Post Number: 1277
kenny: I know for certain that the DP34 switch has a problem, such that you have to keep it powered from DN receiver at output port 1, to be able to use the FTA on the other outputs. I do not know if SW64 has a similar problem. Now that you have mentioned details the problem might be due to that peculiarity of the DN supplied hardware and switches.
Username: Nydas
Post Number: 1278
fidouh: I asked you to read what I have posted about reception on 61.5 (Echo 3). If you read it is very clear about the problem. So there is no point in asking for help.
You should keep on reading this thread to get more news of what is being done to solve the problem. In the meantime, please READ what I wrote just before your first post.
Username: Lklives
Post Number: 7172
This is an ECM by DN going on, map 57, which is blocking the 61.5....more sats and channels will probably go down tomorrow..Bev too has problems..
Viewsat and sonicviews have had the map57 fix since the last ECM, so they are all working...other recivers will likely release new bins eventually..
Username: Canndy
Www.livefta.com
Post Number: 132
Viewsat, SVs and Pansats are reportedly working.
http://www.livefta.com/forums/showthread.php?t=2325
Username: Usha
United States
I have a fortec classic na receiver and i am trying to download bin 287T but i am using my laptop with a usb cord and the other end has a 9 pin,was wondering if that will work because my laptop has a 15 pin serial port and another problem i am having is that when i tried to download the bin the program ask me to select a com port,i could only choice com port 3 and i pressed download and it displayed a message saying no response from the receiver. Please i need some help. Thanks
Username: Kamalrose
Brampton, Ontario
Post Number: 18
hi i have azria 700 dish network picture in the screen keep shaking. like same when traking is no good in the vcr. need help------------ help me
Username: Ricandlisa
are theses keys working , or do u have new keys , haveing a hard time with the keys help me please
Username: Zibruno
Post Number: 13
Anybody loosing channels?
*orn and some other channels all black?
Am i the only one?
Username: Luckydraw
Quebec
Post Number: 11
can anyone tell me where to go and get the channel list to down load to my reciver,i have a fortec star life time ultra,thank-you in advance
Username: Nydas
Post Number: 1280
Usha: BL Updater 1.4 should give you Com 1-4 choice. Try all the settings 1,2,3,4. To be precise, you downloaded the files from a remote site and are now uploading the file to your receiver. Some people forget to unzip the downloaded file to extract the BIN from it. Unzipping is done using winzip.exe avaialble from http://www.winzip.com
The cable will probably work, if the USB to serial driver is properly installed (it usually is). The cable you have gives a straight RS232 output at the 9 pin end (in most cases). It could be that the cable has a null modem output - in that case you should get a 9 pin M/F null adaptor from Radio Shack and attach it in series at the receiver end.
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through January 19, 2007 [ « Previous ] [ Next » ]
