Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Maxent MX-42HPM20 Troubles
Author Thread: Maxent MX-42HPM20 Troubles
Username: Kuku
I'm having issues with my Maxent plasma and I don't know how to fix them. I have a DVI to HDMI cable running from my HD cable box to the TV. My HD channels work perfectly. However, all of the standard channels are unwatchable. The text is blurry and overlapping, lines are running across the screen, and the images aren't clear. I've looked through the manual and settings and nothing helps.
When I first change from an HD channel to an SD channel, it is crystal clear but then changes resolution to 720x??? and all heck breaks loose. Only fix I have found is to watch SD channels through composite cables, but from other HDTVs I've seen, I shouldn't have to switch the source to get it to work. Any ideas?
Also, does anyone know how to use the Picture-IN-Picture with this tv? I have yet to find a way to change the secondary screen's channel. Anytime I get a channel change, it changes both the main and the sub. Any ideas on that?
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Maxent MX-42HPM20 Troubles [ « Previous ] [ Next » ]
