Home > Message Board > Home Video > DVD Recorders > Dvd recorder with ariza FTA??
Author Thread: Dvd recorder with ariza FTA??
Username: Vhl71
my dtoshiba vr works fine with ariza..but is there a way to control the channel change from dvr so that timer recordings automatically go to the particular channel on ariza 700 and record.
I have IR cable with the receiver and it does not have codes for fta receivers.
I need recording with no manual input ..it automatically records ch 140 (espn) for example every day at a specific time..
at present i need to manually make sure my ariza channel is set to 140 for thist
Relevant Product Info
Username: Satscanner
Beaversbush, Sportsmans P...
Great White ...
Post Number: 962
Not shure about the ariza and doubt it .Pansat has the bins with tivo codes included.Your bin should say TIVO included.
Username: Tigger_woods
Flutopia
Post Number: 139
How long is a Chinaman?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > DVD Recorders > Dvd recorder with ariza FTA?? [ « Previous ] [ Next » ]
