Thread: Pansat 2700 |
Bronze Member Username: Skypatel
Post Number: 19 Registered: May-06
| Posted on Monday, January 15, 2007 - 04:14 pm: |
Hi I am new to this. So please help. I got Pansat 2700 receiver. I have 3 satellite (110, 119, 61.5). I did a scan on 3 satelliet. I have following problems. 1. I get more than 1000 channels, but all the channels are repeated many time and not in order. 2. I don't get asian channel which are on 61.5? How do I get those channels. Do I new to put new keys, and if so, how do I do it. Thanks for the help |
Gold Member Username: Prfrmnj
Post Number: 1307 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 04:17 pm: |
What is the entire setup? What switch? What LNB? Location? Any other receivers? Need all this info in order to help. However, before answering those questions I suggest you read a few threads here which contain installation and instructions for what you have asked. |
Post Number: 1308 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 04:19 pm: |
Start by reading here: http://forum.ecoustics.com/bbs/messages/2/313709.html |
Post Number: 1309 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 04:22 pm: |
More info here: http://forum.ecoustics.com/bbs/messages/2/310224.html |
Post Number: 21 Registered: May-06
| Posted on Monday, January 15, 2007 - 04:24 pm: |
I have 2 satellite. (1st is 110 and 119, and 2nd is 61.5) Switch is DP500 I only have 1 receiver |
Post Number: 22 Registered: May-06
| Posted on Monday, January 15, 2007 - 04:29 pm: |
I have 1 dishpro twin (110 and 119) and 1 single lnd (61.5), and it is connected to a switch DP500 |
Post Number: 1312 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 04:34 pm: |
Go to the threads I told you and find out for sure what you have based on the illustrations. |
Post Number: 1313 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 04:35 pm: |
By the way, there is no dish 500 switch. Do you have a DP32???? |
Bronze Member Username: Rogybe
Post Number: 21 Registered: Dec-06
| Posted on Monday, January 15, 2007 - 06:31 pm: |
I am curious how you will do this because i have done some experiment on DP Twin Lnbf and Pansat 2700, My experience is that DP Lnbf and Diseq switch didnt work good. I could do it only if I use 2 duals on Dish 500 and connect each to Diseq. With the DP and Diseq I can download only one satellite and when I try to get another it downloads the one already downloaded and I get double channels from one satellite. The dish is good I have good signal on both satellites. |
Silver Member Username: Ke5aqn
Shawnee,
OK
Post Number: 304 Registered: Sep-06
| Posted on Monday, January 15, 2007 - 07:41 pm: |
dont feel bad I have a dish 500 and I hate it as soon as the ice melts I am replacing it with something else tired of fighting it..I have tried every switch-no switch 22k on-off combo you can think of with no good results....one time it likes one setting the next time it like a diferant one....its almost funny |
Post Number: 1320 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 07:53 pm: |
I've posted this just about everywhere. With DishProPlus you have to install as I stated in the links above. If you are using DishPro (Twin or Quad) then all you need is a DP32 switch. All DP switches are very FTA Friendly and the DishPro (twin or quad) work great. The Dish Pro Plus on the other hand is a little harder to get to work. |
Post Number: 1321 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 07:56 pm: |
Roger - You cannot use a DISEcQ switch with the DishPro LNBs. They have an internal switch. All you have to do is use a DP32 and connect the DishPro LNBs to it. Problem solved. You do have to configure the antena's DISEcQ setting as if you had one, but you won't be using one. 119 - Port 1 110 - Port 2 61.5 - Port 3 |
