Thread: Channel list |
Bronze Member Username: Grub
Post Number: 29 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 12:54 pm: |
hope this isnt to dumb, when i unzip a downloaded channel list and open it a menu comes up asking what program i want to open it with, note pad word pad....hope someone can help. thks |
Post Number: 30 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 12:58 pm: |
also the file is .cmproj format |
Gold Member Username: Prfrmnj
Post Number: 1294 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 01:28 pm: |
You need to download and install Channel Master. That is the format for that channel list you have. |
Post Number: 31 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 01:40 pm: |
great, do i get that from where i downloaded the list or does it matter where i get it thks... you helped me before and i thank you again..btw any suggestions on where i get it |
Gold Member Username: Leew
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1260 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 01:57 pm: |
Channelmaster is a FTA editing software. You can upload your channel list from your receiver and edit allows you to delete, move, and rename channels and satellites. It saves a lot of time and doesn't force you to push the buttons on the remote all the time newest update is below http://www.sharpc.com/CM/update.aspx some receivers you need to upload the channels from your receiver using the loader for your receiver. Some you can upload it directly |
Post Number: 33 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 02:02 pm: |
thks jen and pr iam going to get it now from your link ... i'll let you know thanks your all great |
Post Number: 34 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 02:23 pm: |
thats great i can open the file now and play around with it thks again...if i can help you..i fix boats.atvs.sleds |
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1261 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 02:39 pm: |
Post Number: 1299 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 02:43 pm: |
Mira fresca! Deja de estar moviendote asi! Just kidding!!!! |
Post Number: 35 Registered: Nov-06
| Posted on Monday, January 15, 2007 - 02:57 pm: |
are you rubbing your bumb on me lol..thks again |
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1264 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 03:16 pm: |
Mira PRFRMNJ ! Te gusta como me muevo ? |
Post Number: 1300 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 03:18 pm: |
Lo mas que me gusta son las curvas que vienen con el movimiento! LOL |
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1265 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 03:30 pm: |
aaahaha... te gusta mi culito... |
Post Number: 36 Registered: Nov-06
help i don't comprehend, i hope i'm not the idiot i haven't learn't that language..spanish..almost looks like french..j'ne comprende pas..i don't speak french either i only know i dont understand...although your help was perfect |
Post Number: 1302 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 03:34 pm: |
Maybe! Just don't hurt me! LMAO |
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1266 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 03:39 pm: |
Alright...alright...do You know PRFRMNJ that I love you! and I'll never hurt you!  |
Silver Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 750 Registered: Dec-06
| Posted on Monday, January 15, 2007 - 03:43 pm: |
Pizza Www.Pizzahut.com Www.Dominos.com Www.PapaJohns.com Www.RoundTablePizza.com Www.NYPizzeria.com Www.NatsPizza.com Www.GodFathers.com Www.ZPizza.com Www.Donatos.com Www.LittleCaesar.com Www.JetsPizza.com Www.AustinsPizza.com Www.Marcos.com Www.CicisPizza.com Omg the word Pizza make any sense to me now!!! WHY!!!!!!!!!!! I mean look at the word. It seems loose. "Pizza," I mean just read this next Paragraph. Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza Pizza pizza |
Silver Member Username: Minn_rocks
H-Town.....
Post Number: 223 Registered: Aug-06
Hey Jen..how come you never show your face??and those legs are bigger than my ...LMAO. |
Post Number: 1303 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 03:44 pm: |
I luv u 2! |
H-Town.....
Post Number: 224 Registered: Aug-06
| Posted on Monday, January 15, 2007 - 03:46 pm: |
ME 3 JEN..LOL |
XXXX!!WWWW,
Yokosuka, ...
Holla Back Y...
Post Number: 1267 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 03:56 pm: |
woo-hoo...I am happy!!!
