Thread: Picture hangs up for a few seconds ? |
Bronze Member Username: 4play
Post Number: 20 Registered: Dec-06
| Posted on Saturday, January 13, 2007 - 11:51 pm: |
Hey gang, I was wondering if anyone has experienced the picture freezing up for a few seconds then says scrambled or bad channel afterwards. I reinstalled the bin but it still does it. Any ideas? Thanks |
Bronze Member Username: Heyhowru2004
Post Number: 37 Registered: Nov-06
| Posted on Sunday, January 14, 2007 - 12:08 am: |
turn off power in the back switch...wait couple minutes...turn it on again |
Post Number: 21 Registered: Dec-06
| Posted on Sunday, January 14, 2007 - 12:16 am: |
i tried that but it still does it |
Silver Member Username: Abj
Post Number: 412 Registered: Feb-06
| Posted on Sunday, January 14, 2007 - 12:20 am: |
or may be you need to do factory reset and rescan.you should not have to load new bin again. Just make sure you remember your settings before you do factory default. |
Gold Member Username: Lklives
Post Number: 7076 Registered: Jan-06
| Posted on Sunday, January 14, 2007 - 09:55 am: |
what receiver and bin are U using?...and do as justice recommended, factory reset and then factory bin , along with resetting the antenna/dish receiver settings, then new scan, be patient let keys auroroll on channel 200, and LATEST bin.. |
Post Number: 22 Registered: Dec-06
| Posted on Sunday, January 14, 2007 - 11:06 pm: |
I have a pansat 2500 and i'm using the 287 bin. i that's the most current one i think. |
Post Number: 7103 Registered: Jan-06
| Posted on Sunday, January 14, 2007 - 11:08 pm: |
Mike...do U need someone to hold your hand too...I have told U 100 times what to do... |
Gold Member Username: Prfrmnj
Post Number: 1276 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 08:56 am: |
Mike: What else do you have connected to your system? If you have the latest bin and your system was working before, then you really need to recheck all connections; switches and LNB's (antena alignments). There is no reason you should be having this problem if you are following all the instructions given to you before. Either that or you are missing information - what have you not told us? |
Post Number: 7114 Registered: Jan-06
| Posted on Monday, January 15, 2007 - 09:22 am: |
hes a newbie who hasn't done any reading...just keeps asking... |
Post Number: 1278 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 09:31 am: |
Sounds that way. I put away my spoon long time ago. |
Post Number: 23 Registered: Dec-06
| Posted on Monday, January 15, 2007 - 09:39 am: |
lk i'm not sure what your problem is. I was doing some reading reading but could not find anything on picture freezing up for a few seconds, so i figured i would ask if anyone else had the same problem or if it was just on my end. Whats the big deal? I reset the factory bin and the latest bin and it took care of the problem. thanks for the help. |
Silver Member Username: Crazy_greek
Post Number: 408 Registered: Jul-06
| Posted on Monday, January 15, 2007 - 10:05 am: |
Hey LK You should be nice today, your team has made it for another week. Maybe more? BTW don't forget to put a case of Bud Light on ice for the game. |
Post Number: 1282 Registered: Oct-05
| Posted on Monday, January 15, 2007 - 10:41 am: |
Yuengling Black and Tan or Dos XX Amber for me! LOL |
