Thread: SAMSUNG TECH HELP COLOR WHEEL PROB |
New member Username: Mrage
Post Number: 3 Registered: Jan-07
| Posted on Friday, January 12, 2007 - 02:11 pm: |
I installed a new color wheel in my hlp 5063 and the color on my tv isnt correct can someone help me with the correct settings in the factory menu? |
Gold Member Username: Fyi
Dallas,
Texas
Post Number: 1012 Registered: May-05
| Posted on Friday, January 12, 2007 - 05:09 pm: |
I replaced one in a 5063, but no SM tweaks were needed. The wheel I used was a BP96-00674A. If your color is way off there may be another cause. A loose or dirty connection at one of the wire harnesses is something to check. |
Post Number: 5 Registered: Jan-07
| Posted on Friday, January 12, 2007 - 11:37 pm: |
there are two wires coming off the color wheel. do you know what each one is responsible for? if blue white white wires are in charge of the color i will swap the old one into the new color wheel the old color wheel's color is fine but the wheel is loud and it seems tolock up and shut down the bulb |
Dallas,
Texas
Post Number: 1015 Registered: May-05
| Posted on Saturday, January 13, 2007 - 07:33 am: |
I'm not sure, but I think power is one and some sensor for measuring rpm is the other. It could be a defective wheel right out of the box. Are the color panels exactly the same as the old one? Same number of panels? Do they sound like they spin up the same? What does the picture look like? |
Post Number: 6 Registered: Jan-07
| Posted on Saturday, January 13, 2007 - 07:46 pm: |
fyi do you know what model dmd board you have? the picture on my tv looks like a phot negative |
Dallas,
Texas
Post Number: 1017 Registered: May-05
| Posted on Sunday, January 14, 2007 - 07:52 am: |
I don't have that 5063 set anymore. |
