Thread: How do you check if lnb is bad????? |
Bronze Member Username: Maximus06
Post Number: 51 Registered: Jun-06
| Posted on Friday, January 12, 2007 - 08:29 am: |
Anyone know how to check if lnb is bad wihtout putiing up on the dish??? |
Silver Member Username: Donnie1973
Tennessee
Post Number: 518 Registered: May-06
| Posted on Friday, January 12, 2007 - 09:05 am: |
I dont think u can. u have to install it. |
Silver Member Username: Satscanner
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 739 Registered: Nov-06
| Posted on Friday, January 12, 2007 - 01:22 pm: |
Always take it for a test drive.That way u have tested all the perameters of it's perfomance.some perform better than others but still will work fine.There is a internal calibration attenuator you can ajust also. |
Silver Member Username: Ke5aqn
Shawnee,
OK
Post Number: 219 Registered: Sep-06
| Posted on Friday, January 12, 2007 - 01:45 pm: |
here http://www.satcure.co.uk/tech/lnb2.htm you will find a super good site explaining LNB's. It will show you all about LNB's. As the site explains the Test equipment costs thousands of $$ and it takes time to check an LNB across its entire frequency range. here is how I test one: First I use a KNOWN good one to point a dish to a sat then I change to the LNB I want to test....if it fails I try to Aline it if that fails I trash it. I find LNB's every week for FREE FREE FREE on houses not being used for example. is short NO you can not test a lnb without it being on a dish antenna pointed to a satellite. hope that helps |
Silver Member Username: Tapeman
Post Number: 380 Registered: Oct-06
| Posted on Friday, January 12, 2007 - 02:10 pm: |
Great part listing I'm glad the guy admits he is not a good mathematician similarly his physics and electronics maybe good enough for people that drive on the wrong side of the road. Not recommended by King |
Silver Member Username: Crazy_greek
Post Number: 393 Registered: Jul-06
| Posted on Friday, January 12, 2007 - 03:02 pm: |
Hey maximus The only way you can find out if your LNB is any good without putting it on the Dish is to take it to a Satellite dealer, most of the dealers will check it for you at no charge. Or you can put it on your Dish and run a short piece of coaxial cable from your LNB to a Satellite Finder meter and the wire from your receiver to the meter. |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 740 Registered: Nov-06
| Posted on Friday, January 12, 2007 - 03:59 pm: |
Test driving also will include temperature changes and moisture/condensation issues that "test equipment won't.I don't know how many times i've had electronic components work fine while being tested only to fail in service,or have interminent problems because of other variables."For the price of these disposable lnb's," IF in Doubt Toss it Out" is probally the best solution.I don't now anyone personnally thats tests them for free.If you test drive on the wrong side of the road,its still a test drive. |
Post Number: 381 Registered: Oct-06
| Posted on Friday, January 12, 2007 - 04:22 pm: |
Yes This test tells you if open or short if it does at all Sat Finder is a compas Sat finder can't give you any data or respond to any at all. LNB can be bad and Sat finder still point to direction. Can't use a voltmeter Meter either This is the point You can't measure any frequency that high Most Oscilloscopes at best One or Two GHz Or hardly find a generator that can Generate any such high frequency So best choice pick a SAT that already genrates a known frequency and see if you can display it on a Monitor via receiver. |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 743 Registered: Nov-06
| Posted on Friday, January 12, 2007 - 04:29 pm: |
mmmmm ?..microwaves.....microwave oven,I got an Idea! |
Shawnee,
OK
Post Number: 229 Registered: Sep-06
| Posted on Friday, January 12, 2007 - 04:32 pm: |
from satscanner "For the price of these disposable lnb's," IF in Doubt Toss it Out" is probally the best solution.I don't now anyone personnally thats tests them for free." the only time I heard of someone taking one to a dealer to get it tested the dealer just gave them a new one and "tossed" the "in question" one. Like we have both stated here they are FREE FREE FREE all over the planet so its not worth the trouble. |
Post Number: 382 Registered: Oct-06
| Posted on Friday, January 12, 2007 - 04:41 pm: |
Micro wave Why didn't I think of it So put LNB with coax in microwave No DISEqC straight in The question is where does the other end goes? I got an idea Do you know where..... Just kidding Scanner |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 746 Registered: Nov-06
| Posted on Friday, January 12, 2007 - 04:50 pm: |
Tell Bill Hunter hold it,well you look for your meter.lol |
Post Number: 397 Registered: Jul-06
| Posted on Friday, January 12, 2007 - 05:11 pm: |
Hey maximus Like I said, your best bet is to take your LNB to a Satellite Dealer, maybe the dealers around your area are as nice as the ones around here. Other then that the answer to your question is NO.As you can see no one here knows. |
Post Number: 383 Registered: Oct-06
| Posted on Friday, January 12, 2007 - 09:26 pm: |
Kavin What do you mean no one knows? I answered the guy in post 381 |
Bronze Member Username: Pegg
Post Number: 36 Registered: Aug-06
| Posted on Monday, January 15, 2007 - 12:42 am: |
What is an average life of the most common LNBs? If LNB is dead, would it mean no signals at all or it also affects the level? |
Shawnee,
OK
Post Number: 272 Registered: Sep-06
| Posted on Monday, January 15, 2007 - 12:52 am: |
Pegg, I have seen them not get a signal at all or get one with no quality so it could do ether . Best policy is if in doubt throw it out. Like I think scatscanner said on this thread. |
