Thread: Mitsubishi WS-55905 color problem. |
New member Username: Baylenthesky
San Diego,
CA
US
Post Number: 1 Registered: Jan-07
| Posted on Tuesday, January 09, 2007 - 10:40 pm: |
Hey all, found this forum a few days ago while searching for a solution to my Mitsubishi WS-55905 color problem. As far as I know (not much by the way) nobody has posted a problem related to mine, so I decided to give it a try. Problem is, my TV can no longer display the color red. I went into convergence and found out there was no red. Is this a simple matter of replacing parts, and if so, which is it? Or am I doomed? Thanks for reading this post, I appreciate all comments! -Cuong |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 96 Registered: Nov-06
| Posted on Wednesday, January 10, 2007 - 09:48 pm: |
$300 to $500 for the repair, depending on who does it. That's if the red CRT isn't shot, then it's junk. ($600 to $900) |
San Diego,
CA
US
Post Number: 2 Registered: Jan-07
| Posted on Thursday, January 11, 2007 - 02:53 am: |
First off, thank you for replying. Do you happen to know if it's a simple matter of replacing parts? Or if you have some repair instructions on it that'd be great too. |
