Home > Message Board > Home Video > Digital Recorders > Cant get into setup wizard [8300HDv2.2]
Author Thread: Cant get into setup wizard [8300HDv2.2]
Username: Neirin
Good Evening,
On monday my regular box died so I brought it in and since I have a hdtv I decided to trade up for a DVR box.
I have the SA 8300HD v2.2 and I try following what the manual says, leave TV on, keep box powered off but plugged into working socket. I do the guide + info and all I get is a message that says Press "cbl" to turn on your cable box.
So then I went on to SAs site and found their .pdf manual and it says press cbl on the remote to put the remote into cbl mode and I figured that would help, but no go.
For reference I live in orange county new york and Time Warner Cable is my provider.
Thanks in advance...
Relevant Product Info
Username: Tapeman
Post Number: 557
No
Cable box must be off during this setup. TV on
You must press (Guide and info) at same time from the box not the remote control
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > Digital Recorders > Cant get into setup wizard [8300HDv2.2] [ « Previous ] [ Next » ]
