Thread: New 27" LCD...speaker help...thx. |
New member Username: Unhuskersfan1
MN
United States
Post Number: 1 Registered: Jan-07
| Posted on Tuesday, January 09, 2007 - 09:54 am: |
Hello all, newbie here, both to the forum and to HDTV's. I bought an 'intro' HDTV, a 27" Digimate. I have it hooked up, and it looks pretty good, but I'm trying to get my woofer to work with the TV, but I'm not having any luck. The speakers were an extra for my Dell computer, and I was hoping I could use them through my tv?!?! From the sub, there is three wires coming from the main plug, two going to small speakers, and one that hooks up to the computer, with a standard male computer end. On the TV itself, there is a 'PC audio in' plug which I tried, but I get nothing but fuz. There is a sub plug, so even if I tried to use only the sub itself w/o the two speakers, the two ends are different. I hope that made sense. Any help would be much appreciated. Chad |
Platinum Member Username: Project6
Post Number: 12342 Registered: Dec-03
| Posted on Tuesday, January 09, 2007 - 06:19 pm: |
Check your TV for RCA audio outputs. They are usually color coded red and white and usually labeled "Audio Out". You will need this outputs to connect to your computer's speakers. I am assuming that you have powered speakers, so you will need a ministereo to RCA plug adapter. You will then connect this to your TV's output, plug in your computer speakers and you should be in business. The PC Audio In of your TV is for external sources utilizing your TV's speakers. |
Post Number: 12343 Registered: Dec-03
| Posted on Tuesday, January 09, 2007 - 06:20 pm: |
And you will also need RCA cables to connect the audio output of your TV to the mini stereo to RCA adapter. |
MN
United States
Post Number: 2 Registered: Jan-07
| Posted on Wednesday, January 10, 2007 - 06:55 am: |
Thanks guys! I'll give 'er a go and let you know how it goes. Take care, Chad |
