Thread: Ws65807 component identification |
New member Username: Jocooter
Carmel ,
In
Post Number: 3 Registered: Jan-07
| Posted on Sunday, January 07, 2007 - 10:19 am: |
http://home.indy.rr.com/jocooter/IMAGE015.jpg as you can see in pic there is a component burnt between f9a02 and f9a04 fuses. I need to know this components specs. Thanks in advance... |
Carmel ,
In
Post Number: 4 Registered: Jan-07
| Posted on Sunday, January 07, 2007 - 10:44 am: |
resistor R9A67, I just need to know the value of resistor or if someone could take a good pic so I can see colored bands. |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 88 Registered: Nov-06
| Posted on Monday, January 08, 2007 - 09:20 am: |
If it's feeding a boost diode, it should be something like a 1/2 ohm. Have you checked it? Sometimes those 1/8 watt resisters look like their cooked when they are really good. |
