Thread: Problem with 32 inch RCA model F32645 cable setup |
New member Username: Grifman
Post Number: 1 Registered: Jan-07
| Posted on Wednesday, January 03, 2007 - 08:58 pm: |
I am having problems getting this TV set up with my cable. I am not using a cable box, but the auto channel programming is not working. I can only get one channel. The option for the auto programming never appears neither during the setup process, nor in the channel setup in the main menu. According to the manual the auto programming wont't appear if the set is on a cable box - but it's not, the cable is plugged directly into the back of the TV. Anyone got any idea what I've failed to do. I've read through the manual several times but can't figure anything out. |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 84 Registered: Nov-06
| Posted on Monday, January 08, 2007 - 08:01 am: |
Can you direct access more than one channel? Are you on digital cable? If so, you are going to have to use the box. |
New member Username: Superpea
Alberta
Post Number: 1 Registered: Feb-09
| Posted on Monday, February 16, 2009 - 11:14 pm: |
Hello! We are having the Exact Same Problem!
Just picked up this t.v. from a friend and we are trying to program the channels, onscreen or with our universal.. nothing works.. I noticed your query was sent last year, so I'm really hoping you found a solution. We have one channel.. the cable is plugged directly into the back and auto-programming doesn't seem to be available. Can you help? Thank-you, in advance! Have a good evening! |
