Home > Message Board > Home Video > DVD Players > Archive through February 02, 2007 > DVDs all of the sudden play garbled
Author Thread: DVDs all of the sudden play garbled
Username: Eric_p
Hello,
Looking for some troubleshooting help. I have a Toshiba DVD player that has been hooked up tot he same yamaha home theater and toshibas TV for 5 years now with no problem. Yesterday when I went to watch a dvd it was discolored and wavy. This happened with every disc I tried. I hooked the dvd player directly into the tv and the same. I hooked the dvd player to a different TV and everything is OK. I believe it is the TV that is the problem. Cable works fine on the TV and so does the VCR hooked to it. Any ideas of what I can try to get the DVD and TV to play nice together?
Username: Samijubal
Post Number: 3178
Check the cables.
Username: Eric_p
I have checked the cables, even tried using a whole different set...still the same.
Username: Joe_c
Atlanta, GA
Post Number: 1216
Component connection or s-vid?
Username: Samijubal
Post Number: 3180
If it is s-video, move the cable where it plugs into the TV around a little, if it doesn't do anything, do the same on the player. I've had to replace s-video plugs in electronics before.
Home > Message Board > Home Video > DVD Players > Archive through February 02, 2007 > DVDs all of the sudden play garbled [ « Previous ] [ Next » ]
