Thread: Problem with VCRs |
New member Username: Emmliz
PA
Post Number: 2 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 05:31 pm: |
Hi, I have two problematic combo units which are relatively new (i.e. less than 2 years old), but no longer under guarantee. The first is a Go-Video DVD/VCR combo, model# DV2140. One day, it wouldn't eject the video tape, and then diplayed an ERR message on the screen. It hasn't worked since, and I can't get the tape out. I have tried unplugging and plugging it back in, but to no avail. The Customer Support for Go-Video was extremely 'unsupportive.' The second unit is a Panasonic TV/VCR/DVD combo, model# PV-DF205. The TV and DVD are fine. The video unit picture stopped working one day. The sound is fine, but the picture is just squiggly lines. I have tried cleaning the heads (more than once), but it doesn't make any difference. Can anyone offer me any advice. Thanks - Liz |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3187 Registered: Jul-04
| Posted on Friday, January 05, 2007 - 11:34 pm: |
The Panasonic probably needs the heads cleaned. Tape head cleaners are pretty useless. |
New member Username: Rochel
Post Number: 1 Registered: Apr-07
| Posted on Sunday, April 08, 2007 - 01:29 pm: |
I have a Broksonic VCR/TV combo. The image now displayed is green & black and only in the center of the screen. I don't have the manual or the original remote. Is there a way to fix this? |
