Home > Message Board > Home Video > Rear Projection TVs > Mitsubishi tv problem > Archive through February 13, 2006
Author Thread: Archive through February 13, 2006
I have a mitsubishi cs-35401. I have audio and video, I have high voltage on CTR but the screen is blank. when I use video in, I also have audio but the screen is still blank. How can i fix this?
Relevant Product Info
Mitsubishi rear projection 46 inch TV WS46807, 2001 model. Turned on. Screen started to light up, then died. Sound OK. Sort of like some fuse blew. I Know something about electronics, but have no service manual, know nothing about mitsubishi, and am afraid of a large unnecessary bill so want some ideas first.Any help?
Username: Scooby_nj
Newton, NJ
US
Hi everyone I a hoping that maybe you can help me. I have a Mitsubishi Big Screen TV Vs-5006R. It seems that maybe the projector has moved from position as all I get when I turn it on is very wavey lines and no adjusting of the remote seems to make it stop. The kids were playing Dance Dance Revolution and it has done this ever since. Any ideas on how I can fix this. Could really use some help on this one
bron
I have a Mitsubishi 55" hdtv that I've had for about 6 years or so. The red bulb has gone out and I was wondering if anyone knew if they are hard to replace by myself or if it's a better idea to have it done by a professional? I just didn't want to throw away money for a pro to do it if all it takes is unscrewing the back panel and screwing in the bulb. Also, I was wondering if anyone knows what a replacement bulb would cost? Thanks for any help you can give!
Username: John_s
Columbus, Ohio
US
Post Number: 463
Tomas, HiramA, Shelly Allen and bron:
For help see Paul's post of September 26, 2005 on this thread.
Have WT46807 (a smaller version of WS 55807, the more popular 55 inch), about 4 years old. Suddenly lost raster (picture), but sound OK. Despite sarcasim from John S. (referencing Paul's thread "TV broken, get it fixed" etc.), upon research in this and other threads, found leaking capacitor in PnP was normally the problem. Lo and behold, found a leaking cap, which leaked over one of the small wire fuses. Read a number of threads about either replacing the caps or bypassing the PnP module, but it referred to other models (mostly VS****). Nothing specific in this model, though the principle is the same since the PnP leakage problem is the same. I have no service manual schematic for this model at present. And the module it has leaked on seems to be a bit more than a stand alone PnP module. I wonder how the whole thing comes out, or whether I could just bypass the PnP altogether from the top of the module without removing and repairing or replacing it. Anyone familiar with the WT46807/WS55807/WS65807 series and this problem, who could give me some practical tips? Apparently, the leaking caps in the PnP is a major Mitsubishi flaw causing loss of picture. (I saw one thread where someone is actually considering a class action lawsuit on this problem.)
bueno he visto que casi todos tienen el mismo problema pero ninguno ha mostrado alguna solucion
yo espero conseguir el diagrama de la wt-42313 y si encuetro alguna solucion o duda les volvere a escribir esta pronto
10/07/05
I have Mitsubishi Diamond 65 inch tv. the picture warps at the center,making it narrower then outter side of the picture. WHAT'S WRONG ?
Mitsubullshit
I just bought a WS-55515. It has a built-in HDTV tuner. We hooked it up and got all the local HD channels just fine. All of a sudden, a week later all of the HD channels disappear. I suspect something is wrong with the built-in tuner. I called tech support and he said it could be the tuner and referred me to call for service. I asked IF THIS IS A COMMON PROBLEM AMONG THIS MODEL. He said 'no'.
Now of course i'm not gonna call service. If a TV needs service after one week of use, I don't want it. I'm thinking of returning it and buying a different brand. Anyone got any suggestions? After reading this thread, I'm never going with mitsubishi again. I don't care if I have to pay more for a better brand. As long as it will last for a while, I'll take it.
Username: Wearenotalone69
Post Number: 96
Mitsubullshit,
ANY product can need service after 1 week. There are going to be defective units /parts.
Read this post and maybe you'll feel better. At least you have a TV that IS working (minus the HD channels)http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=474384#POST474384
It took me 8 or 9 months to get a "working" tv.
Your problem is one reason I'd rather have an external tuner.
I've had 3 HD tuner's, the first dying after a few days which is weird because it was a display model (Most electronics dies in the first 30 days, if it survives the first 30 days it will have a normal service life, barring cold solders)
The second tuner which was brand-new dying in a day or so.
The third tuner continues to work.. Third times a charm I guess :-)
The most cost effective thing would be to have the set repaired, of course you probally "want" a "new" set I would think.
The problem with a new set will be by returning the TV that drives up costs to the mfg, which in turn causes them to raise prices.
If they CAN swap out the tuner, I'd try that first if you are happy with the set otherwise.
All brands are prone to "problems". Mit has been in the business for a while so I would think they do make good products overall.
They are selling MILLIONS of these sets so of course you are going to "run accross" threads in which people are having problems. The more they sell the more chances for problems to appear.
I feel for you, but I would give them a chance to repair it before saying you'll never buy another one of their products.
Read the above thread... It took me 8-9 months and about 100+ hours of my time or more to finally get a working TV.
BTW: I'm not a big fan of electronics that has everything "built-in".... One component dies and the whole thing has to go in for service.
Post Number: 97
Mitsubullshit,
One more thought... in alot of towns the HD stations will use the same transmitter... "Maybe" they are having "problems" on their end.
Mitsu green light click
For the people looking for service codes or other calibration instructions, check out this site:
http://myweb.accessus.net/~090/how2adj.html
I'm having the same green light click as others and found that site in my searching. From reading here is sounds like a coolant leak. Will call a service tech.
Here's another link I found on this board about the problem I am having.
http://www.network54.com/Forum/message?forumid=91557&messageid=1060376241
Eowynhope
I've read every post here and some of you guys post great info, thanks.
I do have a problem though, my tv is experiencing the "bow-tie" effect, where the (in my case) the red and green is off, and squezed in the middle. I plan on calling a serviceman to come and check it out, but they charge $50 to just come and look it. Any reason why this might happen?
Thanks
Eowynhope@aol.com
(Please email me if you can, I might not check back here for a while)
Eowynhope
Thanks
Eowynhope@aol.com
i have an mitsubishi 55" hdtv and i just bought an hd cable box but i dont see the hd port in the back of my tv any reasons why? help people
Username: Vmm2004
Need help with Mitsubishi 50" VS50803 Mfg Dt Jan 1999.
Blue is completely off in both HDTV mode and standard mode. I spend day in realigning it. Everything worked great. I turned TV on next day and blue is off again.
Any ides, What might be wrong.
Thanks in advance.
Hi, I am lookinig for some info. I have a Mitsubishi Big Screen TV (in a wooded case). I don't know the exact model or year. We actually found it a couple of years ago. It has a great picture. Someitmes we can get certain channels and sometimes those same channels are not available to view. However the channels that we do get all of the time are excellent. What may be the problem?
Username: Wattsyurz
I'm sure that some of us have electronics training before we'd dream of attempting repair, so why not give it a try? Why is it always "Pay the man?"
The reason for the failure is that it's planned. If the item lasts too long, no return customers. Why is it that the parts are not available? I see this strategy in new homes, too. After only a few years, the place is falling down. As of this date, the Maytag repairman is only on the hook for a year. No wonder he's fishing.
Anyways, YES. Be pissed. Their engineers timed your bad luck. They could build a tv to last 10 years and be infinitely serviceable. Buy another brand.
Have a 2-1/2 year old Mitsubishi WS-55511 that just went out on me. Looks like it has the same problem posted on this website. It won't even turn on so I'm guessing its the power supply board. I also had problems with the blue lamp converging. Has anyone gone after Mistubishi for a solution? I'm probably out at leat $600 for this repair!
Thank you HiramA and Dish Network! My 1996 Mitsubishi big screen projection TV has been to the repair shop twice in the last 2 months with the symptoms you describe and is still not working properly. I just called the service shop and read the info you provided about the PiP module to the tech who has been doing the repair work. Hopefully he'll be able to fix the problem for me now. Thank you again for the very useful information!
hello everyone, i have a mitsubishi hd1080, on the main screen i cant get a clear picture thru any of the inputs its blurry and grayish, but i can get a clear picture thru the PIP feature but i just cant seem to get it thru the main screen, does n e body here have any ideas on wut i can do?
My WS65807, when watching in the 4:3 ratio, has grey vertical bars on the left and right side that used to gradually change in size. The movement was inperceivable and I assumed this movement of the image was to prevent burn in. Unfortunately I did not notice when the movement stopped working. Now I have a pink cast the size of a 4:3 ratio picture. When watching in 16:9 or HD, I can see the very slight pink field in the background. I assume something quit working and that resulted in the burned in color cast. If I can get the movement working again I am hoping the color cast will not get worse.
Has anyone else experienced this problem? Any suggestions will be appreciated.
Hi, I have Mitsubushi project TV model TS-4753 for 10 years already, it works fine until 2 month ago. it started has shaked screen in the first 5 min of the first power on everyday, and it becomes no screen (black screen) only audio last week. Can any expert tell me what sympton might be? And is that worthy to repair? Thanks the tips first.
Post Number: 180
Without wasting a bunch of time... The boards in the these (and ALL mass produced sets) are soldered by a process called wave soldering...
It does a ok job IF all the components to be soldered are of the same "size".... a smaller component needing LESS heat, a bigger one needing MORE heat to be properly soldered.
What happens is the large components don't get enough heat.. and then a bad solder pops up...
The fix, to re-solder.... works most of the time unless there is some type of backfeed that burns something out due to the bad solder.
Sounds like something in the HV power section...
Is it worth it to repair?
NO, more than likely if you have to PAY someone...
Maybe if you have some "time" and can find the bad solder yourself and redo it.
Hope the info had been of help to you.
we bought a tv and love it but the kids were playing with the remote and set the password and v-chip on pg now we can only watch pg rated and under shows. we have no idea what to do. everyone says they didnt do in and we have no idea what the password is. is there anyway to reset it or a mastercode please help.
Post Number: 195
RE: we bought a tv and love it but the kids were playing with the remote and set the password and v-chip on
1: list the model number
2: Info on reseting the V-chip should be in the owners manual
3: Most of time the manual can be downloaded for free from the mfg's website.
I have no idea if this is correct for your model TV, but have you tried unplugging the set overnight for example?
PS: Post back the "fix".
Desert Southwest TV lover
Mitsubushi TV lost remote channel 9 is "locked" how do I unlock it???
I have a Mitsubishi Video Scan System VS-403R. We bought it used and it worked fine for a couple of months. Now the sound works but there is no picture. We had a tech out and he said there are no parts for it, he did not look at for more than a minute or two. Before I trash it I want to know if there is anything I can do. If anyone knows anything please help. I also need to know the age of the TV.
Paul need not reply
Username: John_s
Columbus, Ohio
US
Post Number: 495
You could get a second opinion, but it'll most likely be a waste of time and money. Mitsubishi always put stickers on the back indicating date of manufacture, so unless it has fallen off, it's on the back somewhere.
Parts availability is questionable on this TV.
http://forum.doityourself.com/showthread.php?t=108096
Net Commando
I have a recently purchased WD-62628 DLP TV. I am very happy with the picture, but am having problems with the Net Command. I am unable to teach the TV the REW, FFWD, STOP and PLAY functions to my Scientific Atlanta 3800HD DVR. I've tried just about everything. Anyone else having this problem?
I have an old Mitsibushi model CK2694R. It has worhed great for many (?) years but now all of a sudden, no sound. Any ideas ? Can I hook up to a surround sound and have sound ?
Thanks
Misstique
Hi all,
Perhaps some of you might find some helpful
tips at this website link:
http://www.e-repair.co.uk/tips.htm
virginislander
My VS-45609 has failed for the second time. First time, leaking coolant from the projection tubes damaged large signal board. Mits replaced board free (set was one month past warranty) but I still paid the techie. Now, four years after purchase, the same problem. Board not available any more. Was offered great price on 55" set delivered (we are in the USVI where everything costs more) and will take it. Mits followed through and called w/progress reports. I have 50 yrs experience in electronics (heavy stuff) and wouldn't think of going into the board. TVs no longer are made up of simple components but use specialized IC's and parts. The "turn-off" mode is a protection function to avoid burning a spot in the tube phosphors. Down here, we replace PC's and TV's every three years due to salt. Every mfr has problems.
TV Turns Off
Good information on Mitsubishi repairs here: http://wa6ati.com/Mga-tip.html.
This stuff is pretty scary and foreign to most of us, but the reason we come to these boards is to share info so that we can do our own repairs (or save money in some other way). I respect TV repair professionals, but find that an average person with good info, patience, and the right tools can accomplish almost anything.
TV Turns Off
Anyone interested in or know of a Mitsubishi parts exchange? It sounds like a lot of folks here are going to ditch their sets and buy new, but since we have different problems, we could be sharing/selling parts.
The first step would be to begin properly identifying problems and connecting part numbers to model numbers.
Need help changing video format to full screen when using new CABLE/HD/DVR (Motorola BMC9012) with a 3yr. old Mitsu WS-55859. Adelphia says that only a few HD channels use a full screen video input. I have to switch back to ANT-A to watch almost all cable channels so that the side bars don't burn into screen. If my HDTV is to old, is there any software upgrade? Obviously, I am not an AV tech guy, but would appreciate the help.
Thanks
Username: John_s
Columbus, Ohio
US
Post Number: 508
Doesn't your TV have some sort of stretch mode on your other input?
ALL HD broadcasts use full screen and should not seed any sort of stretch mode, but 4:3 standard def broadcasts do.
Just moved 1500 miles and my 55" HD will not turn on--no power at all. Even the cable people had no suggestions. Anyone help me--please?
Prisiclla
My mitsubishi screen t.v. high definition is on a red light that says light above it don't know how to fix it please help.
Prisiclla
Have a 45607 and basically, after reading ALL these notes, am not going to waste anymore of MY life on this piece of crap. Give Paul a break, at least he has a hobbie! If you are that angry with him, you are either incredibly stupid - or you work for Mitsubishi. By the way, some of the spelling I've seen is atrocious. Forget a TV, buy a fricking dictionary.
p.s. I just went back to Mitsubishi.com again and they are very Shultz from Hogan's Heores about the 45607. They "know nozhink."
You carry that torch Paul!
I just bought a new Dell XPS with an awesome screen and sound system. I'd rather have 19 inches that do it right, than 52 inches that do nothing!
Sock it to me SUCKA!
Could you tell me what to do ( if any)...My Mitsubishi VS 607 (Manufactured in 1994) and a red tent to the screen. I tried adjusting the color scale, but no luck. Do I need to demagetize it or something...I am really trying to keep it. So if you can help it would be great.
My model does the same thing and it won't turn on.I have had it with this set. It also seems that they have a manufacturing problem from all the posts that are available. I think I will buy new. But it won't be a Mitsubishi for sure!!!!!
I have a mitsubishi big screen about 5 years old and it is on ext1 and wants a four didgit code no one seems to know the code has anyone had this problem and if so what can be done!!
My 20 inch Mitsubishi colour TV was purchased in 1995. If I keep volume in Very low with my REMOTE then I can heard very little sound. But if I try to increase volume with REMOTE then my TV become totally soundless. Is it (IF)(Intermediate Frequency)problem? Thanks
Username: John_s
Columbus, Ohio
US
Post Number: 518
Khaled, can you adjust volume via the control on the TV itself?
I have Mitsubishi TV CT-330B3ES and my problam is that I can not change only chanal. Of every program still same chanal-Icannot change . Pleas halp my.
Hallo I have TV Mitsubishi CT-33B3ES and the problem is if I change program I can but if I have to change the channel I can’t do it. The number is always the same. For ex. I enter MENU and I can change program, PAL or SECAM, and when I can change the cannel or band CH or S the TV can’t resave this information and the number is always the same.
hi i have a mitsubishi vs-4552 the problem is that there is burned spot in the center of the screen but if i change the channel the picture is perfect for a couple of seconds if any body has any info or tips please reply.
Username: Hymrod
I have a #46 Inch HDTV Misubishi Diamond something or other. I got it in 2000. It has mad low hours - and just last night- poof- I turn it on and fuzzy, colored snow on every input from my HDTV tuner to rabbit ears. The MENU graphics etc work but are kind of fuzzy, as are the TV INFO # and letters etc. I got it at Sound Advice brand new 5 years ago, of course warranty ended 3 months ago....Any suggestions ? I tried resetting everything - DVD plays the same colored snow crap but the pictures change based on input. In other words everything else works.
can anyone help me out here? i recently got a mitsubishi CS-3803 from my girlfriend's parents, that they were going to throw out, because the sound doesn't work. i'm wondering if it is something that i can fix myself, have serviced, or if i should just throw it out. i have no idea how old it is, i have no manual and no remote for it. however, the picture is fine, all channels come in clear, there is just "zero" sound. if i unplug the cable from it, i can hear some slight static from the snow on the screen, otherwise, nothing. i figuered that if it was blown speakers, i would hear crackling. if anyone has any ideas or suggestions, i'd be greatly appreciative. i realize that the television isn't anything amazing, but it is a nice upgrade from my old junk, and i'd like to get it to work at an affordable price.
thank you.
HiramA
Mits WT46807 (46" version of WS55807 rear projection). Sound OK. No raster or picture. No OSD. Error code self-diagnostic microprocessor doesn't work either. No filaments to picture tubes (light box). Horiz. output transistor tested OK.
Seems like a HV failure. Failure of power to the self-diagnostic microprocessor might provide some additional clues of where power failure is. Because you have to disconnect chassis from CRT light box (and other items in cabinet) to take out chassis and reach parts underneath the boards, one cannot power up TV to trace power voltages.
Repair would be $500+ for labor. A new Philips or Toshiba 51 in. was recently going for $800. So only worth it for self-repair.
And a catastrophic HV failure is usually the easiest to find (if only I could power it on). Parts are not expensive if a whole board doesn't need repair, which is unlikely when a stressed HV power supply part fails, and even the horz. output transistor (the most expensive transistor) is only $14.
Anyone else had this problem with this or similar models?
VicktoriaS
