Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Bush 32" LCD Color probs
Author Thread: Bush 32" LCD Color probs
Username: Estring
Hebburn, Tyne and Wear
UK
I am also having probs with what should be white showing as blue. Also bright lines of red and green. The set is only 2 month's old. Signal thru Telewest cable. Uk. Any of you guy's got any ideas B4 I phone the engineer? Cheers JM
Username: Imustbecrazy
Post Number: 65
John;
I'm guessing that your tv has multiple inputs? Is this problem on the other inputs, too?
Username: Estring
UK
Yes it is and the problem was the same using both. I eventually found out what the problem was after talking to the engineer, who had seen the problem before. Apparently this particular set was prone to being fitted with a faulty circuit board. He also suggested this board would be difficult to get hold of,and it would probably be some time before it could be replaced...He said the set,(Bush 32" LCD) was made by a different company in Turkey, and just plated up for sale as Bush. He said Bush didn't actually make telly's at all!
I was told the best sets are made by our oriental friends, so after a tellyless Xmas, a wife on the rampage and an argument with Argos (never again!) I'm hopefully ordering a new Panasonic 32" LCD tomorrow.
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Bush 32" LCD Color probs [ « Previous ] [ Next » ]
