Home > Message Board > Home Video > TV Basics > Archive through April 02, 2007 > Help with Magnavox 27MS343S TV bright...
Author Thread: Help with Magnavox 27MS343S TV brightness problem
Username: Otimus
I've had this problem quite a while.. and well, I don't know if this will be an apt explanation or not. But anyways, it has this thing.. where it seems to get brighter in dark scenes.. and lighter in dark scenes. For example, say.. in The Legend of Zelda: Twilight Princess, when you use Z-Targetting, it brings up two black-letterbox bars on the screen. This makes it seem to think it's "darker", and the screen gets a bit brighter., and so on. There is no option to turn this off. It's really bugging me :-( Is there anything at all I can do? I had an old Philips/magnavox TV a whiles back that had an auto-something or another that did the same thing, and it let you turn it off in the options.. this one, however, does not. Any help would be much appreciated.. as I have scoured the net for HOURS to find anything, and came up with nil.
Username: Rockyrulz11
Stratford, CT
not a way to turn off, it's a built in technology feature.
Home > Message Board > Home Video > TV Basics > Archive through April 02, 2007 > Help with Magnavox 27MS343S TV bright... [ « Previous ] [ Next » ]
