Thread: Lost my sound on 32" rca console tv |
New member Username: Douellette88
Maine
Post Number: 1 Registered: Dec-06
| Posted on Wednesday, December 20, 2006 - 08:50 pm: |
i have a 32" rca model: g31100ck...in the back it has external speaker inputs and a switch for internal/external/both...one day i hooked up some speakers and turned it on there was the loud semi-hipitched sound coming from the speakers, so i turned it off..unhooked the external speakers and turned it back on, but then the tv had no sound at all..could someone tell me how to fix it? thanks. |
Maine
Post Number: 2 Registered: Dec-06
| Posted on Friday, December 22, 2006 - 08:49 am: |
can someone help me? |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 69 Registered: Nov-06
| Posted on Monday, December 25, 2006 - 08:00 pm: |
Where the external speakers hook up to an external amp at the same time? If so, you blew the outputs in the tv. Call a tech or connect the rca's outputs to the external amp. |
Maine
Post Number: 6 Registered: Dec-06
| Posted on Tuesday, December 26, 2006 - 09:56 am: |
no they were not..i just had the ext./int. switch on the back in the middle so that both would be on |
Dahlonega,
GA
Post Number: 71 Registered: Nov-06
| Posted on Tuesday, December 26, 2006 - 10:05 am: |
It still sounds like you blew the outputs. Call a tech ($100 plus repair)or use the rca variable line outputs connected to an external amp and speakers |
