Home > Message Board > Home Video > Rear Projection TVs > Archive through January 29, 2007 > Toshiba 72 MX195
Author Thread: Toshiba 72 MX195
Username: Jamco
I own a 72 Mx195.
I've had the light engine replace once, because of a loud sqeeling noise eminating from it.
I recently noticed a shadow that runs diag. from the bottom right of the screen towords the top left that I have never noticed before.
My question is, is this normal or could this be another light engine or something else?
I tried to contact Toshiba, but all I get is recorded messages, and over 2 hour wait time on the phone.
Thank you in advance
Username: Stevestar99
Dahlonega, GA
Post Number: 49
Pull the screen. It's sounds like some kind of trash in the optics. Cobwebs have been know to produce strange shadows in the picture.
Username: Jamco
Thanks Steve, but do you think that cob webs would accumilate in within 6 months, or anything else??
Dahlonega, GA
Post Number: 57
I don't know. The reason I say it sounds like something in the optics is, "electronic shadows" are usually linear in shape and run on the trailing edges of images. They will show up on the right side of the screen from top to bottom. The fact that you have one that's left to right and top to bottom makes me think it might be something with the optics. Post a good picture of it. If the set is only 6 months old and under warranty, don't fool with it and call the same guy that did the first repair.
Username: Jamco
Thanks Steve that's what I will do.
Username: Chardy
Sam, I don't know where you live but try this number 1 800 268 3404 and ask for Quammy he works for Toshiba. He's very knowledgable and helped me out with all my questions.
Home > Message Board > Home Video > Rear Projection TVs > Archive through January 29, 2007 > Toshiba 72 MX195 [ « Previous ] [ Next » ]
