Thread: Help Please! (Akai 5498 HDTV) |
New member Username: Ia_chiefs_fan
Post Number: 1 Registered: Nov-05
| Posted on Saturday, December 09, 2006 - 10:15 am: |
I've had my Akai for a couple years and it has been great! However, my kids turned it on this morning and the picture is all messed up. It looks like the convergence is completely shot. I can get into the convergence menu with the "Mute 183" and I see the red lines are way out of whack. It has been about a year or better since I last adjusted this. How do you switch between the different colored guns? It pulls up green first; how do I get to red? What would cause my tv to suddenly lose it's convergence settings? Thanks |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 51 Registered: Nov-06
| Posted on Sunday, December 10, 2006 - 10:11 am: |
Your red convergence output IC has failed. Trying to adjust it isn't going to help. |
Post Number: 2 Registered: Nov-05
| Posted on Sunday, December 10, 2006 - 10:14 pm: |
Well I got into it but, like you indicated, can't really fix the problem. However, I was able to move the green and blue lines so they matched the red. I could move the red up or down but not left to right. I have made the tv to where it is at least viewable. Will the problem get progressively worse or will it likely just stay like this? |
Dahlonega,
GA
Post Number: 60 Registered: Nov-06
| Posted on Sunday, December 10, 2006 - 11:38 pm: |
Could stay like that for quite some time, until the blue goes out. So if you have it fixed, make sure the blue and green get replaced at the same time. |
