Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > Question for fyi
Author Thread: Question for fyi
Username: Eymyel827
Post Number: 11
jsut a quick question about hdmi cable. i recently switched to an hdmi cable and im not getting any sound from any station, also the sound shrunk from a full screen to a 16:9 with gray borderlines. jsut wondeirng if i could get a full screen from hdmi connection. i have a samsung S6187W.
Username: Fyi
Dallas, Texas
Post Number: 949
HDMI engineers would like you to think that their connector is plug n play. Hardware compatibility and firmware versions are critical to the hand shake. Some setups just don't work well. Sound can be dealt with in other ways, thankfully. The old 4:3 aspect ratio is forced from local digital HD networks during the daytime, but expands to full 16:9 during prime-time HD shows at night. If you know the broadcast should be 16:9 and it isn't, check the output aspect ratio of the cable or sat box menu.
Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > Question for fyi [ « Previous ] [ Next » ]
