Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Problems taping from freeview
Author Thread: Problems taping from freeview
Username: Baboboy
Nottingham, Nottingham
England
I currently have a philips 26PF5521D/10 tv with built in freeview. At the moment I am unable to record from freeview at all. I have both scart sockets plugged from the TV to the video as recomended by philips but still it will not record. I can record from analoguw with no problems. At the moment if i toggle through the ext settings on the video it shows bbc1 but if i switch to analogue chanels it displays. It displays bbc1 onext 1 even if it is sky sports news. Please help
Username: Cynic
What i did was Connect the aerial to the TV, then a scart lead from the TV to my DVD recorder, then a lead from Recorder (video out) to the aerial socket on the TV I cab then record to DVD from the Freeview, via AV2
The only problem with this method is your TV has to be at least on Standby mode or turned on
A much better way (What i have done) is to connect another Freeview box to the DVD Recorder, i can then record Freeview while the TV is turned off or i am away from home, I don`t like keeping the TV on Standby when i am not in the house
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through February 01, 2007 > Problems taping from freeview [ « Previous ] [ Next » ]
