Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > MITS WS-55819 Rear Proj - Blue Conver.
Author Thread: MITS WS-55819 Rear Proj - Blue Conver.
Username: Salnacr
Please help? I am having problems with the Blue Convergence. There is a slight blue hue on the picture, most noticible around white area. I have tried the Convergence setting but is seems that the right/horizontal part of the "+" is slighlty longer then the left.
Username: Stevestar99
Dahlonega, GA
Post Number: 30
It may not be a convergence problem. Turn down the brightness and contrast. If the blue seems to pull back in, the blue CRT is degrading. You can try adjusting the focus and screen controls to develop the best possible picture. You should also clean the mirror and lens too. That's assuming that this is a CRT set and not a DLP wide screen.
Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > MITS WS-55819 Rear Proj - Blue Conver. [ « Previous ] [ Next » ]
