Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > Testing a DLP bulb
Author Thread: Testing a DLP bulb
Username: Jagtech
Lethbridge, Alberta
Just bought a dead RCA HD61LPW175, don't know if it's worth fixing. Is there any way, even an ohmmeter test, to test these bulbs?
TIA, Dave
Username: Kano
BC
Post Number: 1124
Usually a burnt out bulb will have some sort of indication through the front panel lights.
If the TV doesn't turn on at all it is likely a power supply problem.
Check the RCA owner's manual on-line to see if the front panel lights indicate a blown bulb.
Username: Jagtech
Lethbridge, Alberta
The front panel lights do the usual flash five times thing, but that really only indicates that the lamp isn't illuminated, doesn't it? Apparently a previous serviceman replaced a "module", but found the set still wouldn't work. Then they abandoned it. I don't know if they tried a new bulb. It would be nice if there were a way to tell for sure if a bulb is pooched.
Home > Message Board > Home Video > Rear Projection TVs > Archive through December 19, 2006 > Testing a DLP bulb [ « Previous ] [ Next » ]
