Thread: Dvd to iPod |
Bronze Member Username: Kevintsa
Post Number: 32 Registered: Jun-06
| Posted on Tuesday, November 14, 2006 - 01:43 pm: |
Here is a comparison between several DVD to iPod Converters. The converters are Xilisoft DVD to iPod Converter Download Cucusoft DVD to iPod Converter Download PQ DVD to iPod Video Converter Download Super DVD to iPod Converter Download Movkit DVD to iPod Ripper Download 1 Performance ( conversion speed and stability) While using software, users always expect fast speed and efficient performance. It costs much time to convert DVD files, about 30 minutes to convert a one-hour DVD to MP4, indeed a headache. And if you have many DVDs to be converted, what should you do? Find a highly efficient tool or otherwise you will waste quite long time in conversion and your PC will also be bound with enormous amount of processes. I spent a relatively long time to test in this aspect, since an general DVD file lasts 1 and a half hour and the average conversion time is about 1 hour .After all these trials , I came to find some problems. Firstly, if the whole DVD is to be converted, the speed competition of all soft end in a tie, needing the same time with the original file¡¯s playing time. But here to point out that thanks to some special settings of Xilisoft and Movkit, the two soft affords automatic check of CPU type, and accordingly choose customized processing algorithm so as to increase the conversion speed. If you recorded a concert and want to convert only several songs rather than the whole disk, Xilisoft is recommendable for its saving of more than half of the average time, quite amazing speed! Output quality Video quality: Most of iPod MP4 users make it a movie house on the go, thus putting much attention on the quality of video. Cutting edge DVD converters will bring along no loss in video or image quality, enabling joy of watching movies with high definition. If otherwise, it will not only hurt your eyes, but make you headache with flopping images. Audio quality: iPod plays a leading role in the output system of high quality. If after conversion, you get damned bad audio effect out of a piece of great music, it must be unbearable. So never think of a converter that will afflict your ear and brain. All the mentioned software, except Super, support customized settings for video resolution, video/audio bit rate, audio sampling rate, etc. PQDVD stands out in this aspect. We can observe from the interface an adjusting click for different output quality, with demonstration of the size of output file, enabling users to make a balance between the file size and the expected quality. Price tag Every one expects the most return for the least pay, so here to check out the price tags of these software Product Cucusoft PQ Super Xilisoft Movkit Price $29.95 $34.95 $29.95 $29 $29.95 After comparison, I¡¯d like to give some suggestion that Xilisoft DVD to iPod Converter and PQ DVD Converter are two most recommendable gadgets for their customized setting of parameters, conversion speed and high quality output. |
New member Username: Mikeok
Post Number: 1 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 10:12 pm: |
Do you know I see dvd to ipod converter, convert dvd to ipod -- ipod zune psp video converter software released in a website ? |
