Thread: Replacement Diamond Shield for Mitsubishi VS-45605 |
New member Username: Guykinley
Post Number: 2 Registered: Nov-06
| Posted on Monday, November 06, 2006 - 09:07 pm: |
I have a Mitsubishi VS-45605, and it works great. Only problem is that the Diamond Shield is cracked. I can get a replacement from Mitsu for ~$100, but I don't know how to install it. The local tech wants $500 after estimate, labor and parts, and the TV just isn't worth that these days. Any advice on how to remove the bezel or housing? Its not obvious to me. |
Bronze Member Username: Stevestar99
Dahlonega,
GA
Post Number: 20 Registered: Nov-06
| Posted on Tuesday, November 28, 2006 - 12:20 am: |
Mitsu's used two different ways to get the screen off. The older ones have a little tab in the middle of the drop down door that you have to move to get to the screw that releases the cross bar, so you can get to the bottom screen screws, then push up on the screen. The newer version has a hidden screw behind the Mitsubishi name plate on the front of the set. Pull out on the spring loaded name plate a bit and turn it to expose the hidden screw. The rest is petty much the same. On most of them you have to get the cross bar off first before you can get to anything else |
