Thread: Feedback or a "hum" when using TV |
New member Username: Vthotcarl
Post Number: 1 Registered: Oct-06
| Posted on Monday, October 30, 2006 - 08:02 pm: |
I have an 42" LG DU-42PX12X. When watching the tv through the componet cables, there is a noticable "humm" or feedback type noise. It is only through the componet cables that comcast provided. When i watch through the normal coaxial cable there is no hum. The comcast box is the HD 8300 box. What can i do??? |
Post Number: 2 Registered: Oct-06
| Posted on Wednesday, November 01, 2006 - 05:43 pm: |
come on.......can someone help me |
Silver Member Username: Cableguy
Somewhere on...
U.S.
Post Number: 865 Registered: Mar-05
| Posted on Thursday, November 02, 2006 - 08:07 am: |
I don't work for Comcast so it's hard to help when I don't know their equipment. Can you verify the volume on the 8300 is all the way up? The hum you are hearing could be related to a bad ground in some equipment that's plugged in. Usually a good way to check is to run an extension cord from another room and isolate each piece of equipment. |
Gold Member Username: John_s
Post Number: 1158 Registered: Feb-04
| Posted on Thursday, November 02, 2006 - 08:31 am: |
ryan, since component cables carry video only, the first thing I would do is to replace the audio cord. This would eliminate the possibility of a defective cord. |
