Thread: WAITING FOR PIC , KEY ARE CORRECT, FILE 361BIN PANSAT 3500 ????? WHY |
Bronze Member Username: Ashrafshu
NY,
NY
Post Number: 28 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 09:45 pm: |
CAN any body help? |
Silver Member Username: Bertoro
Toronto,
Ontario
Post Number: 290 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 09:49 pm: |
which key youhave on rite now? |
NY,
NY
Post Number: 29 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 09:53 pm: |
96 is active, changed Fri Oct 27 20:22:15 2006 86: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 96: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD |
NY,
NY
Post Number: 30 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 09:58 pm: |
Toronto,
Ontario
Post Number: 294 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 10:02 pm: |
i think that is your problem...please set key 00 as active..try and let me know |
Silver Member Username: Jenifer_contreras
PIMP Member Yokosuka, Ka...
Post Number: 442 Registered: Jul-06
| Posted on Friday, October 27, 2006 - 10:11 pm: |
I have no Charly...my VSE down! |
NY,
NY
Post Number: 32 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 10:12 pm: |
HOw to we set the key to be active ? i dont know how to do it. |
Toronto,
Ontario
Post Number: 296 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 10:16 pm: |
what is your box? |
NY,
NY
Post Number: 33 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 10:17 pm: |
How to we set the key to be active ? i dont know how to do it? ferenck massella thanks for the help. |
NY,
NY
Post Number: 34 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 10:18 pm: |
PANSAT 3500 |
Gold Member Username: Lklives
Post Number: 5003 Registered: Jan-06
| Posted on Friday, October 27, 2006 - 10:19 pm: |
Thread: SOLUTION TO PROBLEM Qban SATv Silver Member Username: Cooldude69 Post Number: 103 Registered: Apr-06 Posted on Friday, October 27, 2006 - 06:14 pm: -------------------------------------------------------------------------------- DN is playing around with the 5th pair of keys... The solution is to change the 5th pair in keys 00 to DB and MAKE SURE YOU HAVE AUTOROLL TURNED OFF! The correct key 00 for DN is: 00: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 -------------------------------------------------------------------------------- DN and Bev keys ..as of 27 Oct 10:12PM (EST) Nagra2 Keys Dish Provider 0101: Last Updated (Oct27 3pm) Key0: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 Key1: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD(Active) Bev Provider 0901: Last Updated (Oct27 10am) key0: 6A 77 04 91 58 1D 0C 41 EA FD 0B F5 27 02 D1 0C Key1: 49 C8 46 22 EB E6 78 8E 43 88 AD B1 C8 AA EA 51 HAVE AUTOROLL TURNED OFF!! |
Toronto,
Ontario
Post Number: 297 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 10:21 pm: |
when u set the key..how many lines do u see on the screen? |
Toronto,
Ontario
Post Number: 298 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 10:25 pm: |
mine is a pansat 2500..i have 2 lines for DN. 00 01 but also have key number..to select avtive key...00 or 01 |
Toronto,
Ontario
Post Number: 299 Registered: Apr-05
| Posted on Friday, October 27, 2006 - 10:36 pm: |
ok seems that u have fix your problem... anyway it must say prov. id......0101 key number.....00/01 to make active key data...8 pairs 8 pairs |
New member Username: Proxmat
Post Number: 10 Registered: Jun-06
Same kind of problem on ViewSat Extreme, well sort of: correct Bin (worked until this Afternoon)correct new set of keys etc. Free chanels do show (103, 500 etc.) info showes but no picture. Tried power off /on, waiting for it if all loads up after about 2 hours no such luck. Yes did double check if keys correct. When keys chnged in the aft. the pic did froze. Turned power OFF for about 30sec. then back ON, keys must have rolled picture was back for about 15 minutes. Then froze again. Tried the same procedure - unsuccesfully. Did change keys manualy and result is described above. Suspect the binery file may have gotten corupted. But "ferenck massella" got my attention here: just how do you change / re-set key from "inactive" to an "active"?? Sorry "ferenck" but this seemes (if technicaly possible) to be illogical because, at the moment, Key 00 (86) is actually inactive / pasive one and the key 01 (96) is active one. Please explain this more in detail. Appreciate. Thanks. Anyone else knowing how to resolve the above V/S Extreme problem please be welcome as well. |
Post Number: 5006 Registered: Jan-06
| Posted on Friday, October 27, 2006 - 10:51 pm: |
Just do as stated above..manually enter the keys and SHUT OFF autoroll..its that simple...just enter the 4 lines of DN keys.. CAS Line Code Info Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1 Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1 Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1 For Receivers with only two Key Lines (which are VERY few), Enter Active Idea Key into 00 and 01 |
Bronze Member Username: Nalbouz
Post Number: 70 Registered: Oct-05
| Posted on Friday, October 27, 2006 - 10:55 pm: |
lk, thanks , i change it to DB, it's working |
Bronze Member Username: Proxmat
Post Number: 11 Registered: Jun-06
| Posted on Saturday, October 28, 2006 - 01:51 am: |
Thanks for trying to help LK. This was the first time ever I was to change the keys manualy (on V/S Xtreem, before had diferent STB's) and somehow I missed that there are 2 screens (00 AND 01) even though it did not feel right changing only 1 screen. In any case this important detail has been ommissed on every description on 'how to manualy enter keys' (on VSX) that I came to find. I know sounds stupid not to know but it's not wastefull info when one does this procedure for the very 1st time on this particular STB. Anyway it worked, it just took about 3 hours of reading different forums until I came across a post on Al7bar that mentioned something about "changing both screens" and then it hit me. Again for anyone out there - ViewSat Extreem + manual change of keys (1st turn Autoroll OFF) = success only if changed on BOTH /00 and 01/SCREENS. |
Post Number: 5009 Registered: Jan-06
| Posted on Saturday, October 28, 2006 - 09:13 am: |
there are 2 screens obviously because U have to enter 2 Different keys 00 and 01 and change them ...that should NOT need to be written...and all instructions will tell U to change from key 00 to key 01..
Bronze Member Username: 18_volts_baby
Post Number: 24 Registered: Aug-06
| Posted on Saturday, October 28, 2006 - 09:40 am: |
Listen up everyone you don't have 2 change both keys all the time.. You only need 2 change which ever key is active Thats why it's called "ACTIVE" It's 16 bit encryption not 32 bit  |
Post Number: 5015 Registered: Jan-06
| Posted on Saturday, October 28, 2006 - 01:44 pm: |
Just make sure U have BOTH keys correct!...any moron knows U don't have to change something that is already correct! |
