Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > SOLUTION TO PROBLEM
Author Thread: SOLUTION TO PROBLEM
Username: Cooldude69
Post Number: 103
DN is playing around with the 5th pair of keys...
The solution is to change the 5th pair in keys 00 to DB and MAKE SURE YOU HAVE AUTOROLL TURNED OFF!
The correct keys for DN ARE:
00: E6 80 E6 01 DB 7D EE 4D
9B 12 EC 90 62 27 AD 26
HAVE AUTOROLL TURNED OFF!!
Username: Lionking
Post Number: 27
can any one please give me step by step instructions to enter keys inot c**lsat 5000 please
Username: Impala1977
Post Number: 120
Thanks, got all channels back.
Username: Kabob
Post Number: 18
Its called Self Support from Blacklist and team!
Support is even slower than the Site!
Its an easy fix - start the support responce clock - Tick, Tick...
Username: Vndpatel
Post Number: 72
that didnt work for me
Username: Jmill1948
Chester, Va
Usa
Post Number: 1037
works
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > SOLUTION TO PROBLEM [ « Previous ] [ Next » ]
