Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Pansat 2500a no access to parental co...
Author Thread: Pansat 2500a no access to parental control
Username: Murline
Miami
Usa
Pls bear with me I need some help. I have a pansat 2500a and since the release of the recent bin files (halleluja) I have loaded in the past days the latest bin files 281, 281T and 282 but my box is still not working. The problem is that I cannot get acces to the parental control as it is blacked out in the main menu. I am afraid I am back to the factory setting mode. How can I get my box up and going again. Any advice appreciated. Pls be as specific as you can since I am not very knowledgeable. Many thanks in advance.
Username: Prfrmnj
Post Number: 684
You need to configure your antenas and (Through the Installation Menu) then do a Blind Scan. Once you have Channel Data, you'll be able to access Parental Controls. The reason you cant access it right now is because you have no channel data.
Username: Nikk
Post Number: 515
Murline...
Do what PRFRMNJ is telling you, You don't have any sat configured, you have to through that, then do a blind scan and then Voila!! your Parental Control will be there again...
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Pansat 2500a no access to parental co... [ « Previous ] [ Next » ]
