Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Oops, Waiting..(just happened 3:28pm ...
Author Thread: Oops, Waiting..(just happened 3:28pm Et))
Username: Kabob
Post Number: 14
was smooth till 3:28pm ET...
Waiting for pic...
PS3500/361
Username: Runnerguy
Pluto
Post Number: 19
I think 280 not working autoroll now. When new keys come maybe turn off autoroll?
Username: Mc_sunny
Post Number: 538
Dishnetwork NEW KEYS
10-27-06
KEY 00: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26
KEY 01: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD
Username: Osc
PUERTO RICO
Post Number: 176
Nagra2 Keys
Dish Provider 0101: Last Updated (Oct27 3pm)
Key0: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 (Active)
Key1: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD
Bev Provider 0901: Last Updated (Oct27 10am)
key0: 6A 77 04 91 58 1D 0C 41 EA FD 0B F5 27 02 D1 0C
Key1: 49 C8 46 22 EB E6 78 8E 43 88 AD B1 C8 AA EA 51
Username: Ohbeeman
Post Number: 9
I have a Pansat 2700/a and it took 20 min. but it rolled by it's self. At 4.05pm
Username: Abe125
Cali
Post Number: 7
thanks
Username: Nydas
Post Number: 797
On 281T on a clone, my autoroll did not work. I caught it immediately, did a "set default key", reentered both keys and missed only about a minute of the program I was watching.
Username: Sandsman1
Post Number: 30
took about 15 mins for my extreme to roll but it just came back on by it self
Username: Xarnix
Post Number: 8
Nalin,
Do you have your autoroll now off or on. Cause I'm experiencing the same problem but if I go "set default key" and reenter the new keys again, I get the pics back but after 1 min it says "waiting for picture" and when I go back the keys are changed again as previous ones.
Username: Hawaiian_time
Hawaii
Post Number: 689
Arni, autoroll should be off if you are entering keys manually.
Username: Jmill1948
Chester, Va
Usa
Post Number: 1036
running 281 no problems auto roll on and working........
Username: Xarnix
Post Number: 9
Hawaiian, if I leave autoroll off then I do not have any pics at all.
Username: Nydas
Post Number: 801
281T is causing autoroll problems off and on.
Also many receivers, notably coolsats are experiencing key morphing. It is unpredictable.
For people having difficulties, keeping autoroll helps - you just enter the keys manually.
There is a 282T, but it is said to be only for BEV autoroll problems.
Username: Mehul420
my viewsat platinum 2000 doesnt work and my autoroll is on, what should i do?
Username: Mwarrior
Post Number: 13
This might be a stupid question, but under Dish 01 01 01 I see:
"00
08
09
88
89"
Each one has 8 sets of digits, meaning 2 full keys. I just got my FTA (VS Xtreme) a couple of days ago and it doesnt seem to have autorolled. ANy suggestions on where I enter which key in those boxes?
Thanks
Username: Proxmat
Post Number: 9
My VS Extreem rolled just OK, although it took about 30 minutes to happen.
Suggest: if it's not life threatening situation 4U just be patient and wait for keys to roll. If U have original model of STB (not a clone) and correct BIN File it'll happen eventualy.
Patience my friends, patience.
Just my opinion.
Username: Nydas
Post Number: 802
Gee Wizz:
Most people do not have autoroll problems on VS Xtreme
Use Nagravision 2 Keys:
Left half (8 numbers) of Key 00 goes into 08
Right half (8 numbers) of Key 00 goes into 09
Left half (8 numbers) of Key 01 goes into 88
Right half (8 numbers) of Key 01 goes into 89
Username: Runnerguy
Pluto
Post Number: 20
3:53PM CT DN down again, let's see if 281 can roll before freaking out about keys, maybe 15 mins!!
Hawaii
Post Number: 690
Wiz, ignore the first line of numbers.
Username: Sandsman1
Post Number: 31
yea my extreme went dowl again too last time it came back so im not mesin with it haha
Username: Kabob
Post Number: 15
ps3500/361 - Its up, then again Its down...
THe Big Dog is tryin to shake off the Fleas...
May hav found a vunerability! Pansat at least
(BL'll take Forever..., gotta go to the other room, Viewsat adjusting better. Oh well, better swap out the last Pansat before it goes back to bein worth nothin again)
Username: Runnerguy
Pluto
Post Number: 21
281 Auto roll no work w/ Pansat 2500a. must turn of so keys don't change back
Username: Kabob
Post Number: 16
Even I see the AutoRoll problem and what is changin that shouldnt!
As ususal BlTeam is out to lunch!
Gotta go harrass the Total site - its real easy to get their Goat - and Easy to see why PS/BL site has a bad attutude. I understand I own one(but not for long)
Username: Nydas
Post Number: 809
Key morphing problem is common to all receivers, whether you have a VS or a PS, so best to stop unnecessary critisism.
Username: Kabob
Post Number: 17
Excuse me - meant to rattle Future Site
BUt as usual future is S L o o o o o w....
Now wonder thay got a bad attitude...
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Oops, Waiting..(just happened 3:28pm ... [ « Previous ] [ Next » ]
