Thread: HKey/Autoroll HELP NEEDED |
New member Username: Xarnix
Post Number: 1 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 11:36 am: |
Hi Guys, I have Pansat 2700a bin 281T. My current issue is that I put the new key in and then OK and exit. The picture comes up and I get all the channels. BUT after 1 min it disapears, it says waiting for picture. I have tried with Autoroll OFF and I have tried to turn the switch off/on but it does not help. Any suggestions. PLEASE |
Silver Member Username: Crazy_greek
Post Number: 129 Registered: Jul-06
| Posted on Friday, October 27, 2006 - 12:17 pm: |
Hey Arni Go back and check your keys. Sometimes one or two will change. |
Post Number: 2 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 12:23 pm: |
I put the right keys and when I go pack it gives me clear picture with all the channels. But after 1 min it disapears and the keys has been changed to the old ones. |
Silver Member Username: Minn_rock
Post Number: 498 Registered: Aug-06
| Posted on Friday, October 27, 2006 - 12:34 pm: |
Arin, when u DL bin 281T u don't need to entering keys,it autoroll, try to let it stay for few minutes to see what happen...because i using bin 281T too and i haven't enter any keys yeah not even one.. |
Post Number: 3 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 12:43 pm: |
I tried that too. I let it stay overnight and nothing has been happening. It still says waiting for picture. I tried so many options still doesnt work. |
Post Number: 500 Registered: Aug-06
| Posted on Friday, October 27, 2006 - 12:51 pm: |
why don't you DL that bin again, after you finish do not enter any keys in and it will autoroll to the lastest keys for u, it will take a few minutes.. |
Post Number: 130 Registered: Jul-06
| Posted on Friday, October 27, 2006 - 01:06 pm: |
OK Arni Try this go to Parental Control To Autoroll set Charlie & Bev to off OK to "Set default key" Go back take your time and enter all the keys again. After you enter each top & bottom row check your keys & press OK. If you don't get in a hurry this should work. |
Post Number: 4 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 01:14 pm: |
I will try like u said Kavin, and I will let you kow the outcome. |
Post Number: 5 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 02:22 pm: |
Kavin, after I enter the keys do I have to go back and change the Autoroll sets the same as it was before or do I need to leave it off. |
Silver Member Username: Osc
PUERTO RICO
Post Number: 169 Registered: Sep-06
| Posted on Friday, October 27, 2006 - 02:32 pm: |
ARNI THE 281T BIN IS FOR CLONE YOUS RECEIVER IS A CLONE??? |
Post Number: 6 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 02:39 pm: |
Im not sure to be honest with you, Im at work right now. |
PUERTO RICO
Post Number: 171 Registered: Sep-06
| Posted on Friday, October 27, 2006 - 03:09 pm: |
ARNI I GOT A 279 BIN ON MY PANSAT 2700 AND ITS WORKS GREAT...AND THAT BIN HAVE AUTOROLL FIX |
Post Number: 7 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 03:13 pm: |
it worked out great with 281t bin till yesterday, but now it works for a min and then it switches off for some reason. |
Silver Member Username: Nydas
Post Number: 798 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 04:27 pm: |
Arni: You are probably experiencing a key morphing. Set everything off including autoroll and Key code. Do "Set default key". Under Nagravision 2, enter both Key 00 and Key 01, save, set keycode on, save again, exit and switch off at the back. Then switch on. You should have TV. 281T autoroll works about 80-90% of time, but you get really frustrated with key morphing. Charlie was teasing the 5th number of my inactive key a little while ago. |
Post Number: 10 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 05:40 pm: |
Nalin, it does not work either. ANYONE ELSE CAN HELP ME???? |
Silver Member Username: Bones714
SO.California
Post Number: 158 Registered: Mar-05
| Posted on Friday, October 27, 2006 - 05:46 pm: |
Yeah, just re-enter the Key provider keys 00: not 01, starts with E6 80 E6 01 D1 and so on it's just the 00 keys, do that then u should be good |
Bronze Member Username: Xarnix
Post Number: 11 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 05:48 pm: |
king, did you read my issue above. Thats what I did and it does not work. |
Post Number: 806 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 05:49 pm: |
Kingfish: the 5th number of Key 00 is DB. That is the one DN is playing with. |
Bronze Member Username: Hemi426no1
Post Number: 13 Registered: Sep-06
| Posted on Friday, October 27, 2006 - 06:08 pm: |
Do exactly like Kavin Reno Says and it will work. If you dont set defult key it will keep trying to autoroll even when its off. That was my experince anyway. |
Post Number: 14 Registered: Sep-06
| Posted on Friday, October 27, 2006 - 06:11 pm: |
Thanks Kavin. |
