Thread: VS Xtreme freezing |
New member Username: South2
Post Number: 9 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 10:39 am: |
Hi, I have VSX in one room and Pantec in other. I just got them both working by using dual port lnbs and two disc switches (I followed a diagram from one of the posts). Both are working fine, but with one problem.When I turn pantec on or off, picture on VSX freezes with no signal. When I move channels on VSX, it starts working again. This is not a problem when pantec is on and VSX is turned on. Any suggestions? Thanks. |
Bronze Member Username: El_chupacabra_online
Latino america,
Todo
Colombia
Post Number: 23 Registered: Jul-06
| Posted on Friday, October 27, 2006 - 11:13 am: |
Looks like the Pantec suck all the power from the dish. I am sure,your diseqc switch or LNB is F_k Up! check all yor setting,every cables...
Bronze Member Username: South2
Post Number: 11 Registered: Oct-06
| Posted on Friday, October 27, 2006 - 12:30 pm: |
Checked the cables, switches and lnbs. Seem to be working fine as long as both receivers are not on at the same time. So I guess that's what I should do to prevent any damage. Thanks for information. |
New member Username: Kfox
Post Number: 9 Registered: Jun-06
| Posted on Friday, October 27, 2006 - 05:21 pm: |
You have a grounding problem. You can either try gounding the incoming feeds to both stb or buy a 4 X 4 multi switch. Had the same problem and had to change out the diseqc switches and get a 4 x 4 multi switch. Do a search at any reputable for grounding or multi switches |
