Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Loading the channel master
Author Thread: Loading the channel master
Username: Charjam
Post Number: 72
I am kinda new at this and i have never did any channel guides i have successfully loaded 4 bin files and that is the extent of my knowlege . I downloaded the instructions for channel master but it says to click on tools . But i don't see tools when i open the file . What loader do you use or do you use any loader ????? i am connfused Thanks
Username: Nikk
Post Number: 496
David.....
It is not neccesary to load any channel guide into your receiver, you will get a up-to-date channel guide by doing a blind scan, there have been a lot of changes on the TP's these days and probably you will loose several channels one day or another.......
Username: Lklives
Post Number: 4998
Channel Master is a utility program to edit, delete, add , make channel lists , etc...U load the PROGRAM, the same as U do any program for your computer...and U load the channel lists using the same software U use to load bin files..
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Loading the channel master [ « Previous ] [ Next » ]
