Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Pansat 2700a trouble
Author Thread: Pansat 2700a trouble
Username: Farazmo
Post Number: 10
hey guys im having some trouble getting any channels on my pansat 2700a. i havent been using satellite for the past few months since the major ECM in june.
i was using cable for the time being and recently found out that receivers have started working again so i downloaded the latest bin (281) from the future fta site onto my pansat. i connect everything after but now when i just get a no signal message on every channel.
i did a blind scan/satellite scan and im not detecting any channels for some reason.
i was set for BEV and havent changed my satellite position or made any other changes. autoroll is on.
is there something else i need to do after putting the bin?
Username: Charjam
Post Number: 71
281 is for 2500
Username: Mike_m
Post Number: 27
is 281 the lastest bin for 2500 and how would unzip the file thanks
Username: Osc
PUERTO RICO
Post Number: 167
new bin from future-fta.info
pansat 1500a bin 282 update 10/25/06
pansat 2300a bin 260e update 10/25/06
pansat 2500a bin 282 update 10/25/06
pansat 2700a bin 281 update 10/25/06
pansat 3500s/sd bin 364 update 10/25/06
pansat 5000hc bin 3104 update 10/25/06
pansat 6000hxc bin 3129 update 10/25/06
Username: Prfrmnj
Post Number: 682
You need to check your setup and then your atena. Even a gust of wind can move the antena just a couple of degrees and next thing you know - BAMMM - no signal....
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Pansat 2700a trouble [ « Previous ] [ Next » ]
