Thread: Please correct me if im wrong |
Bronze Member Username: Yanniss
Post Number: 86 Registered: Feb-06
| Posted on Thursday, October 26, 2006 - 08:29 pm: |
i have been using viewsat-platnium with bin 060924as and 061007cs both dont roll both . someonme suggsest that i turn everything to zeros and it will roll no no no thanx |
Silver Member Username: Hawaiian_time
Hawaii
Post Number: 678 Registered: Apr-06
| Posted on Thursday, October 26, 2006 - 10:00 pm: |
Did you try turning your vs off and on at the back? The 061007 bin should roll. The last resort would be to flash your receiver with the factory bin and then the 061007 bin. Also make sure that the site you got the bin from is a reputable one. |
Post Number: 88 Registered: Feb-06
| Posted on Thursday, October 26, 2006 - 11:19 pm: |
i did try to turn off my receiver and wait it does not roll and does not show if it';s rolling or not like pansat at least says wait for the pic with the % going up viewsat you wait for black screen and u dont know if u r in right track or not . thanx for ur help the only thing i did not do is flashing ewith the factory bin i just dowloaded the new one on top of the other one . but thanx really for answering and taking your time to help thanx and god bless all keep in touch |
Silver Member Username: Ryersonresurrected
Post Number: 120 Registered: Sep-06
| Posted on Friday, October 27, 2006 - 08:26 am: |
Bronze Member Username: Crippledwarcook
Post Number: 54 Registered: Apr-06
| Posted on Friday, October 27, 2006 - 09:27 am: |
it's not he machine...it's the fcuking retard trying to use it...the viewsat rolls fine, maybe you should do some more reading and figure out what you are doing wrong...until then, go watch your wife scrub her azz in the shower...ROTF |
