Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Searching for a specific channel
Author Thread: Searching for a specific channel
Username: Lynchmob450
Post Number: 35
Is there a way to search out a specific channel? I am looking to find "SPSOU" to catch the Thrashers-Hurricanes game. I looked at my channel listing, but i don;t have this channel.
Is there a way to see what channels are under the "TV###" channels without having to go through each channel manually?
Also, is there a way to scan the dish to search out this specific channel?
Username: Ryersonresurrected
Post Number: 93
I'm not sure if this helps, but Lyngsat com may provide the info u need....
or download channelmaster if ur interested in looking into the channels in each transponder.
hope that helps
Post Number: 37
Thnx for the info, Ryerson!
Username: Ke5aqn
Shawnee, OK
Post Number: 47
I found this with a simple google useing SPSOU
http://www.dishnetwork.com/popUps/programming/channels/index.asp?Show=2&NetwID=5 0384
Username: Ke5aqn
Shawnee, OK
Post Number: 48
Username: Lklives
Post Number: 4966
Both the BEV and Dishnet channel lineup is located in the Forums at Dsscommunity in the FTA general section..
Home > Message Board > Home Video > Satellite TV > Archive through October 28, 2006 > Searching for a specific channel [ « Previous ] [ Next » ]
