Thread: Just got this bin for pansat 2500 clone safe282T |
Bronze Member Username: Brucester
Post Number: 93 Registered: Jul-06
| Posted on Wednesday, October 25, 2006 - 03:47 pm: |
just got this from dssevolution*com works good sofar just to let you know it works have fun all |
Bronze Member Username: Mike_m
Post Number: 26 Registered: Mar-06
| Posted on Thursday, October 26, 2006 - 09:03 am: |
i have a pansat 2500 bins wont download i also tryed the factory bin yet nothing seem to work it says bin complete. yet i still have that damm blinking line going back and forth any suggestion thanks |
Silver Member Username: Minn_rock
Post Number: 490 Registered: Aug-06
| Posted on Thursday, October 26, 2006 - 09:12 am: |
mike, keep try to DN it again until your box reset itself and you r done. it happen to me last night, i try 2 more time and it work.. |
Silver Member Username: Abj
Post Number: 336 Registered: Feb-06
| Posted on Thursday, October 26, 2006 - 09:13 am: |
make sure you open the file |
Bronze Member Username: Shenanigans
Post Number: 35 Registered: Sep-06
| Posted on Thursday, October 26, 2006 - 09:20 am: |
Timing is important. The very second the first green light appears after you flip on the switch on the back of your receiver, click the button to download the file. It may take several tries to get it to work. It has to be timed perfectly. |
Gold Member Username: Lklives
Post Number: 4980 Registered: Jan-06
| Posted on Thursday, October 26, 2006 - 09:26 am: |
Those are called "nite rider lights"...unzip the factory bin and do as Shenanigans told U..then unzip and upload the latest working bin..and reboot receiver from rear switch..and wait and let the latest keys AUTOROLL into your receiver (waiting for picture will occur).. |
