Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > Need Help with Digi-setup
Author Thread: Need Help with Digi-setup
Username: Campe
Got a new Mitsu DLP (WD-52628 with build in QAM) with the very basic Comcast (Seattle area) and am trying to set up to view the local digital channels. I got it to where I scanned all analog and digital off the cable but when I go to the digital channels (81-1, etc) all I get is audio with no video. I can sometimes turn the PIP on and off and the digial feed comes through for about 20 seconds, then I get the blue screen.
Is it me or the signal? The signal meter says its a pretty good signal.
Same thing happens when I connected and scanned directly off my exterior antenna. Any ideas?
tia,
Username: Chmee
Is it possible that Comcast is encrypting these signals? If so, I think you'd need a cable box or cablecard to receive these channels.
Username: Chmee
Oh wait...that won't explain why your getting this problem with OTA. Have you tried contacting Mitsubishi?
Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > Need Help with Digi-setup [ « Previous ] [ Next » ]
