Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through November 15, 2006 > Is Polaroid a good brand?
Author Thread: Is Polaroid a good brand?
Username: Cooldude69
Post Number: 94
I just bought a 19" Plasma Polaroid and I have cable television. The image quality looks way better on my old TV than on this one and im thinking about chaging it for another one.
I already adjusted Brightness, Contrast, Color etc. But nothing.
What do you guys suggest?
Post Number: 97
anyone???
Username: Park8817
Richmodn Hill/Toronto, Ontario
Polaroid is low-end product.
The image quality comes from LCD PANEL Quaility and Video Proessing and system Technologies.
Big Makers have very good video system technologies, Video Chip.
Some of good video chips make LCD TV quality worst.
even you change it with new one, you can not change Panel and Video Chips.
Thanks
Post Number: 98
Thanks alot for you help PDP LCD Repair Guy.
I didnt really understand what you meant by low-end but I have an idea.
So what do you suggest I do. Exchange the TV for a better brand(if so, which is best?), or just keep it?
Username: Park8817
Post Number: 17
Just keep it if you don't mind the delicated quality. And try to color tunnings..
Post Number: 101
Alright. Thanks man :-)
Listen, one more question (sorry, this will be the last one)... Do you think that by getting HDTV the problem will be solved?
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through November 15, 2006 > Is Polaroid a good brand? [ « Previous ] [ Next » ]
