Home > Message Board > Home Video > Direct View TVs > 1995 Mitsubishi reset/degauss ?
Author Thread: 1995 Mitsubishi reset/degauss ?
Username: Maggie_r
Connecticut
Hello. I have a 1995 31" Mitsubishi CS-31303. A couple of weeks ago, it stopped turning on. Actually, when I would press power, it would start to turn on but then would turn off before the screen lit. I called a repair man, but before he could come, someone recommended trying the reset button. After pushing and holding the reset and degauss buttons several times, the tv turned back on and worked fine. This issue recurred twice more, and recovery was successful. However, two days ago the same issue cropped up, and the tv will no longer respond. Any idea what this is, why the degauss and reset buttons wont work anymore, and what I can do to fix it?
Username: Versii
Akron , Ohio
I have a similar problem with my 1994 Mitsubishi VS-4552. It was working good, after I replaced a fuse, then while adjusting the color settings, the screen turned blue, and clicked off. Now i can;t get it to turn back on. This is the only rear-projection tv I have, and I need it for some mods I am doing with Wiimotes and other things.
Please email me at dadisms@gmail.com if you can help. Thanks.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Direct View TVs > 1995 Mitsubishi reset/degauss ? [ « Previous ] [ Next » ]
