Home > Message Board > Home Video > Satellite TV > Archive through October 04, 2006 > Which Dish & LNBs for Viewsat extreme...
Author Thread: Which Dish & LNBs for Viewsat extreme: for DishNET 110 & 119
Username: Hardjelly
Hi, I know that some Dishs and LNBs don't work for Viewsat extreme when trying to get DishNet 110 & 119. I just want to know (if someone can link me to eBay or a reputable site) where I can purchase a Dish AND 2 LNBs. Remember I basically need it for 110 & 119 (or 92 & 91 if I ever change my mind). I just want the DISH and LNBs that are the easiest to use. I'll be using the 4to1 switch that came with the ViewSat, so I'm looking for a dish and LNBs that don't have internal switches. Let me know, any help is appreciated. Thanks
Username: Pukka
Post Number: 52
you need a regular 18'' dish and circular lnb s
Username: Jrq
Post Number: 139
Getting 110 and 119 on one 18" dish can be difficult depending how far north you are; a 18 x 24 will be easier or try two 18" dishes.
Username: Pukka
Post Number: 53
well yes jqr is right, is easier with an oval dish
Username: Hardjelly
How about the Dish Pro 1000+? Its a little bigger than 18". thanks
Home > Message Board > Home Video > Satellite TV > Archive through October 04, 2006 > Which Dish & LNBs for Viewsat extreme... [ « Previous ] [ Next » ]
